Datasheet ADL5910 (Analog Devices)
DescriptionDC to 6 GHz, ≤45 dB Envelope Threshold Detector/Trigger
Pages / Page22 / 1 — DC to 6 GHz, ≤45 dB Envelope Threshold. Detector/Trigger. Data Sheet. …
DC to 6 GHz, ≤45 dB Envelope Threshold. Detector/Trigger. Data Sheet. ADL5910. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADL5910 Analog Devices
DC to 6 GHz, ≤45 dB Envelope Threshold Detector/Trigger Data Sheet ADL5910 FEATURES FUNCTIONAL BLOCK DIAGRAM Envelope threshold detection and latching ENBL VPOS VIN– RST 14 5 7 16 15 Broad input frequency range: dc to 6 GHz ADL5910 ±1.0 dB input range: ≤45 dB DECL 4 ±1.0 dB input level: −30 dBm to +15 dBm at 100 MHz R Q 12 Q Q Programmable threshold and latch reset function S 13 Q ENVELOPE RFIN 1 Propagation delay: 12 ns typical from RFIN to Q/Q latch DETECTOR + All functions temperature and supply stable Operates at 3.3 V from −40°C to +105°C
01 0
Quiescent current: 3.5 mA typical 11 3 2 6 8 9 10
7-
GND VCAL DNC
83 13
Power-down current: 100 μA typical
Figure 1.
16-lead, 3 mm × 3 mm LFCSP package APPLICATIONS Wireless power amplifier input and output protection Wireless receiver input protection RF pulse detection and triggering GENERAL DESCRIPTION
The ADL59101 is a radio frequency (RF) detector that operates programmed threshold to the output latching is 12 ns. The latched from dc to 6 GHz. It provides a programmable envelope event is held on the flip flop until a reset pulse is applied. threshold detection function. The RF input of the ADL5910 is dc-coupled, allowing operation The envelope threshold detection function compares the voltage down to arbitrarily low ac frequencies. It operates on a 3.3 V from an internal envelope detector with a user defined input supply and consumes 3.5 mA. Power-down mode reduces this voltage. When the voltage from the envelope detector exceeds current to 100 μA when a logic low is applied to the ENBL pin. the user defined threshold voltage, an internal comparator The ADL5910 is supplied in a 3 mm × 3 mm, 16-lead LFCSP for captures and latches the event to a set or reset (SR) flip flop. operation over the wide temperature range of −40°C to +105°C. The response time from the RF input signal exceeding the user 1 Protected by U.S. Patent 9,379,675.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION A COMPLETE INPUT PROTECTION CIRCUIT RESET ON ENABLE OR AT POWER-UP IMPROVING FREQUENCY FLATNESS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
