Datasheet AD8362 (Analog Devices) - 2
Description50 Hz to 3.8 GHz 65d dB TruPwr™ Detector
Pages / Page34 / 2 — AD8362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionF
AD8362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• RF Source Booklet
EVALUATION KITS Technical Articles
• AD8362 Evaluation Board • Design a Logamp RF Pulse Detector • Log Amps and Directional Couplers Enable VSWR
DOCUMENTATION
Detection
Application Notes
• Measurement and Control of RF Power, Part I • AN-1040: RF Power Calibration Improves Performance of • Measurement and Control of RF Power, Part II Wireless Transmitters • Measurement and Control of RF Power, Part III • AN-653: Improving Temperature, Stability, and Linearity • Measuring the RF Power in CDMA2000 and W-CDMA High of High Dynamic Range RMS RF Power Detectors Power Amplifiers (HPAs) • AN-691: Operation of RF Detector Products at Low • Measuring VSWR and Gain in Wireless Systems Frequency
Tutorials Data Sheet
• Design and Operation of Automatic Gain Control Loops • AD8362: 50 Hz to 3.8 GHz 65 dB TruPwr™ Detector Data for Receivers in Modern Communication Systems Sheet
DESIGN RESOURCES TOOLS AND SIMULATIONS
• AD8362 Material Declaration • ADIsimPLL™ • PCN-PDN Information • ADIsimRF • Quality And Reliability • AD8362 S-Parameters • Symbols and Footprints • AD8362 S-Parameters
DISCUSSIONS
View all AD8362 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS CHARACTERIZATION SETUP EQUIPMENT ANALYSIS CIRCUIT DESCRIPTION SQUARE LAW DETECTION VOLTAGE vs. POWER CALIBRATION OFFSET ELIMINATION TIME-DOMAIN RESPONSE OF THE CLOSED LOOP OPERATION IN RF MEASUREMENT MODE BASIC CONNECTIONS DEVICE DISABLE RECOMMENDED INPUT COUPLING Choosing Input Coupling Capacitors Single-Ended Input Drive OPERATION AT LOW FREQUENCIES CHOOSING A VALUE FOR CHPF CHOOSING A VALUE FOR CLPF ADJUSTING VTGT TO ACCOMMODATE SIGNALS WITH VERY HIGH CREST FACTORS ALTERING THE SLOPE TEMPERATURE COMPENSATION AND REDUCTION OF TRANSFER FUNCTION RIPPLE TEMPERATURE COMPENSATION AT VARIOUS WiMAX FREQUENCIES UP TO 3.8 GHz OPERATION IN CONTROLLER MODE RMS VOLTMETER WITH 90 dB DYNAMIC RANGE AD8362 EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
