Datasheet AD8361 (Analog Devices) - 5
DescriptionLF to 2.5 GHz TruPwr™ Detector
Pages / Page23 / 5 — AD8361. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. …
RevisionF
File Format / SizePDF / 611 Kb
AD8361. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. ESD CAUTION
AD8361 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Stresses at or above those listed under Absolute Maximum
Table 2.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Supply Voltage VS 5.5 V or any other conditions above those indicated in the SREF, PWDN 0 V, VS operational section of this specification is not implied. IREF VS − 0.3 V, VS Operation beyond the maximum operating conditions for RFIN 1 V rms extended periods may affect product reliability. Equivalent Power, re 50 Ω 13 dBm
ESD CAUTION
Internal Power Dissipation1 200 mW 6-Lead SOT-23 170 mW 8-Lead MSOP 200 mW Maximum Junction Temperature 125°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature Range 300°C (Soldering 60 sec) 1 Specification is for the device in free air. 6-Lead SOT-23: θJA = 230°C/W; θJC = 92°C/W. 8-Lead MSOP: θJA = 200°C/W; θJC = 44°C/W. Rev. F | Page 4 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION Filtering Offset APPLICATION INFORMATION Basic Connections Output Swing Dynamic Range Input Coupling and Matching Input Coupling Using a Series Resistor Selecting the Filter Capacitor Operation at Low Frequencies Power Consumption, Enable and Power-On Volts to dBm Conversion Output Drive Capability and Buffering OUTPUT REFERENCE TEMPERATURE DRIFT COMPENSATION Extended Frequency Characterization EVALUATION BOARD CHARACTERIZATION SETUPS Equipment Analysis OUTLINE DIMENSIONS ORDERING GUIDE
