Datasheet AD8314 (Analog Devices)
DescriptionRF Detector / Controller, 100 MHz TO 2.7 GHz, 45 dB
Pages / Page21 / 1 — 100 MHz to 2.7 GHz, 45 dB. RF Detector/Controller. AD8314. FEATURES. …
RevisionC
File Format / SizePDF / 440 Kb
100 MHz to 2.7 GHz, 45 dB. RF Detector/Controller. AD8314. FEATURES. Complete RF detector/controller function
Datasheet AD8314 Analog Devices, Revision: C
link to page 13 link to page 13
100 MHz to 2.7 GHz, 45 dB RF Detector/Controller AD8314 FEATURES
For convenience, the signal is internally ac-coupled, using a
5 pF capacitor to a load of 3 kΩ in shunt with 2 pF. This high-
Typical range:−58 dBV to −13 dBV
pass coupling, with a corner at approximately 16 MHz,
−45 dBm to 0 dBm, re 50 Ω
determines the lowest operating frequency. Therefore, the source can be dc grounded.
Frequency response from 100 MHz to 2.7 GHz Temperature-stable linear-in-dB response
The AD8314 provides two voltage outputs. The first, V_UP,
Accurate to 2.7 GHz
increases from close to ground to about 1.2 V as the input signal
Rapid response: 70 ns to a 10 dB step
level increases from 1.25 mV to 224 mV. This output is intended
Low power: 12 mW at 2.7 V
for use in measurement mode. Consult the Applications section
Power down to 20 μA
for information on this mode. A capacitor can be connected
between the V_UP and FLTR pins when it is desirable to
increase the time interval over which averaging of the input
Cellular handsets (TDMA, CDMA , GSM)
waveform occurs.
RSSI and TSSI for wireless terminal devices
The second output, V_DN, is an inversion of V_UP but with
Transmitter power measurement and control
twice the slope and offset by a fixed amount. This output starts
at about 2.25 V (provided the supply voltage is ≥3.3 V) for the
GENERAL DESCRIPTION
minimum input and falls to a value close to ground at the The AD8314 is a complete low cost subsystem for the maximum input. This output is intended for analog control measurement and control of RF signals in the frequency range loop applications. A setpoint voltage is applied to VSET, and of 100 MHz to 2.7 GHz, with a typical dynamic range of 45 dB, V_DN is then used to control a VGA or power amplifier. Here intended for use in a wide variety of cellular handsets and other again, an external filter capacitor can be added to extend the wireless devices. It provides a wider dynamic range and better averaging time. Consult the Applications section for accuracy than possible using discrete diode detectors. In information on this mode. particular, its temperature stability is excellent over the full The AD8314 is available in 8-lead MSOP and 8-lead LFCSP operating range of −40°C to +85°C. packages and consumes 4.5 mA from a 2.7 V to 5.5 V supply. Its high sensitivity allows control at low power levels, thus When powered down, the typical sleep current is 20 μA. reducing the amount of power that needs to be coupled to the detector. It is essentially a voltage-responding device, with a typical signal range of 1.25 mV to 224 mV rms or –58 dBV to −13 dBV. This is equivalent to −45 dBm to 0 dBm, re 50 Ω.
FUNCTIONAL BLOCK DIAGRAM FLTR V-I VSET + I-V V_UP DET DET DET DET DET X2 V_DN RFIN + 10dB 10dB 10dB 10dB VPOS BAND GAP OFFSET AD8314 REFERENCE COMPENSATION ENBL
1
COMM
00 6-
(PADDLE)
08 01 Figure 1.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INVERTED OUTPUT APPLICATIONS BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT dBV VS. dBm FILTER CAPACITOR OPERATING IN CONTROLLER MODE POWER-ON AND ENABLE GLITCH INPUT COUPLING OPTIONS INCREASING THE LOGARITHMIC SLOPE IN MEASUREMENT MODE EFFECT OF WAVEFORM TYPE ON INTERCEPT MOBILE HANDSET POWER CONTROL EXAMPLES OPERATION AT 2.7 GHz USING THE LFCSP PACKAGE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
