Datasheet AD8028-KGD-CHIP (Analog Devices)
DescriptionLow Distortion, High Speed Rail-to-Rail Input/Output Amplifier
Pages / Page8 / 1 — Low Distortion, High Speed. Rail-to-Rail Input/Output Amplifier. Known …
RevisionB
File Format / SizePDF / 182 Kb
Low Distortion, High Speed. Rail-to-Rail Input/Output Amplifier. Known Good Die. AD8028-KGD-CHIP. FEATURES. High speed
Datasheet AD8028-KGD-CHIP Analog Devices, Revision: B
link to page 1
Low Distortion, High Speed Rail-to-Rail Input/Output Amplifier Known Good Die AD8028-KGD-CHIP FEATURES
Many rail-to-rail input amplifiers have an input stage that switches
High speed
from one differential pair to another as the input signal crosses a
190 MHz, –3 dB bandwidth (G = +1)
threshold voltage, which causes distortion. The AD8028-KGD-
100 V/µs slew rate
CHIP has a unique feature that allows the user to select the
Low distortion
input crossover threshold voltage through the SELECT pin.
120 dBc @ 1 MHz SFDR
This feature controls the voltage at which the complementary
80 dBc @ 5 MHz SFDR
transistor input pairs switch. The AD8028-KGD-CHIP also has
Selectable input crossover threshold
intrinsically low crossover distortion. With its wide supply
Low noise
voltage range (2.7 V to 12 V) and wide bandwidth (190 MHz),
4.3 nV/√Hz
the AD8028-KGD-CHIP amplifier is designed to work in a
1.6 pA/√Hz
variety of applications where speed and performance are needed on
Low offset voltage: 900 µV max
low supply voltages. The AD8028-KGD-CHIP has a disable
Low power: 6.5 mA/amplifier supply current
mode that is controlled via the SELECT pin.
Disable mode
The AD8028-KGD-CHIP is rated to work over the industrial
Wide supply range: 2.7 V to 12 V
temperature range of –40°C to +125°C.
Known good die (KGD): these die are fully guaranteed to
Additional application and technical information can be found
data sheet specifications
in the AD8028 data sheet.
APPLICATIONS Filters ADC drivers Level shifting Buffering Professional video Low voltage instrumentation GENERAL DESCRIPTION
The AD8028-KGD-CHIP1 is a high speed amplifier with rail-to- rail input and output that operates on low supply voltages and is optimized for high performance and wide dynamic signal range. The AD8028-KGD-CHIP has low noise (4.3 nV/√Hz, 1.6 pA/√Hz) and low distortion (120 dBc at 1 MHz). In applications that use a fraction of or the entire input dynamic range and require low distortion, the AD8028-KGD-CHIP is an ideal choice. 1Protected by U.S. patent numbers 6,486,737B1; 6,518,842B1
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
