Datasheet AD8065-KGD-CHIP (Analog Devices) - 5
DescriptionHigh Performance, 145 MHzFastFET Op Amps
Pages / Page8 / 5 — Known Good Die. AD8065-KGD-CHIP. ABSOLUTE MAXIMUM RATINGS Table 4. ESD …
File Format / SizePDF / 182 Kb
Known Good Die. AD8065-KGD-CHIP. ABSOLUTE MAXIMUM RATINGS Table 4. ESD CAUTION. Parameter. Rating
Known Good Die AD8065-KGD-CHIP ABSOLUTE MAXIMUM RATINGS Table 4 ESD CAUTION Parameter Rating
Known Good Die AD8065-KGD-CHIP ABSOLUTE MAXIMUM RATINGS Table 4. ESD CAUTION Parameter Rating
Supply Voltage 26.4 V Common-Mode Input Voltage VEE − 0.5 V to VCC + 0.5 V Differential Input Voltage ±1.8 V Storage Temperature –65°C to +125°C Operating Temperature Range –40°C to +105°C Junction Temperature 150°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. 0 | Page 5 of 8 Document Outline Features Applications General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
