Datasheet OP284-EP (Analog Devices)
DescriptionPrecision RRIO Dual Operational Amplifier
Pages / Page13 / 1 — Precision RRI0 Dual Operational Amplifier. Enhanced Product. OP284-EP. …
File Format / SizePDF / 252 Kb
Precision RRI0 Dual Operational Amplifier. Enhanced Product. OP284-EP. FEATURES. PIN CONNECTION DIAGRAM. Single-supply operation
Datasheet OP284-EP Analog Devices
Precision RRI0 Dual Operational Amplifier Enhanced Product OP284-EP FEATURES PIN CONNECTION DIAGRAM Single-supply operation OUT A 1 8 V+ Wide bandwidth: 4.25 MHz –IN A 2 7 OUT B +IN A 3 6 –IN B Low offset voltage: 100 μV V– 4 5 +IN B Unity-gain stable High slew rate: 4.0 V/μs OP284-EP
001
TOP VIEW Low noise: 3.9 nV/√Hz (Not to Scale)
12562- Figure 1.
ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) Military temperature range (−55°C to +125°C) Controlled manufacturing baseline 1 assembly/test site 1 fabrication site Enhanced product change notification Qualification data available on request APPLICATIONS Battery-powered instrumentation Power supply control and protection Telecommunications DAC output amplifier ADC input buffer GENERAL DESCRIPTION
The OP284-EP is a dual, single-supply, 4.25 MHz bandwidth and use as an amplifier or buffer for transducers with wide amplifier featuring rail-to-rail inputs and outputs (RRIO). output ranges. Sensors requiring a rail-to-rail input amplifier The OP284-EP is guaranteed to operate from 5 V to 36 V (or include Hal effect, piezoelectric, and resistive transducers. ±2.5 V to ±18 V). The ability to swing rail to rail at both the input and output This amplifier is superb for single-supply applications requiring enables designers to build multistage filters in single-supply both ac and precision dc performance. The combination of systems and to maintain high signal-to-noise ratios. wide bandwidth, low noise, and precision makes the OP284-EP The OP284-EP is specified over the extended industrial useful in a wide variety of applications, including filters and temperature range of −55°C to +125°C. The OP284-EP is instrumentation. available in a SOIC surface-mount package. Other applications for this amplifier include portable telecom- munications equipment, power supply control and protection,
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
