Datasheet OP497 (Analog Devices) - 10
DescriptionPrecision Picoampere Input Current Quad Operational Amplifier
Pages / Page10 / 10 — STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 16-02-04. Approved. …
File Format / SizePDF / 63 Kb
STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 16-02-04. Approved. sources. of. supply. for. SMD. 5962-94521. are. listed. below. for. immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 16-02-04 Approved sources of supply for SMD 5962-94521 are listed below for immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 16-02-04 Approved sources of supply for SMD 5962-94521 are listed below for immediate acquisition information only and shall be added to MIL-HDBK-103 and QML-38535 during the next revision. MIL-HDBK-103 and QML-38535 will be revised to include the addition or deletion of sources. The vendors listed below have agreed to this drawing and a certificate of compliance has been submitted to and accepted by DLA Land and Maritime-VA. This information bulletin is superseded by the next dated revision of MIL-HDBK-103 and QML-38535. DLA Land and Maritime maintains an online database of all current sources of supply at http://www.landandmaritime.dla.mil/Programs/Smcr/. Standard Vendor Vendor microcircuit drawing CAGE similar PIN 1/ number PIN 2/ 5962-9452101MCA 3/ OP497BY/883B 5962-9452101M2A 24355 OP497BRC/883B 1/ The lead finish shown for each PIN representing a hermetic package is the most readily available from the manufacturer listed for that part. If the desired lead finish is not listed contact the vendor to determine its availability. 2/ Caution. Do not use this number for item acquisition. Items acquired to this number may not satisfy the performance requirements of this drawing. 3/ Not available from an approved source of supply. Vendor CAGE Vendor name number and address 24355 Analog Devices Route 1 Industrial Park P.O. Box 9106 Norwood, MA 02062 Point of contact: 804 Woburn Street Wilmington, MA 01887-3462 The information contained herein is disseminated for convenience only and the Government assumes no liability whatsoever for any inaccuracies in the information bulletin.
