Datasheet AD713 (Analog Devices) - 10
DescriptionPrecision, High Speed, BiFET Quad Op Amp
Pages / Page12 / 10 — STANDARD. 5962-90633. MICROCIRCUIT DRAWING
File Format / SizePDF / 123 Kb
STANDARD 5962-90633 MICROCIRCUIT DRAWING
TABLE IIA. Electrical test requirements. Test requirements Subgroups Subgroups (in accordance with (in accordance with MIL-STD-883, MIL-PRF-38535, table III) method 5005, table I) Device Device Device class M class Q class V Interim electrical 1 1 1 parameters (see 4.2) Final electrical 1,2,3,4,12 1/ 1,2,3,4,12 1/ 1,2,3,4,12 1/ parameters (see 4.2) Group A test 1,2,3,4,5,6,9,12 1,2,3,4,5,6,9, 1,2,3,4,5,6,9, requirements (see 4.4) 12 12 Group C end-point electrical 1 1 1,2,3,4,5,6,9, parameters (see 4.4) 12 2/ Group D end-point electrical 1 1 1 parameters (see 4.4) Group E end-point electrical --- --- --- parameters (see 4.4) 1/ PDA applies to subgroup 1. 2/ Delta limits in accordance with table IIB shall be computed with reference to the previous interim electrical parameters. TABLE IIB. Delta limits at +25°C. Parameter 1/ All device types VOS ±10 percent of specified value in table I IIB ±10 percent of specified value in table I 1/ The above parameters shall be recorded before and after the required burn-in and life tests to determine the delta. 4.4.2 Group C inspection. The group C inspection end-point electrical parameters shall be as specified in table IIA herein. 4.4.2.1 Additional criteria for device class M. Steady-state life test conditions, method 1005 of MIL-STD-883: a. Test condition A, B, C, or D. The test circuit shall be maintained by the manufacturer under document revision level control and shall be made available to the preparing or acquiring activity upon request. The test circuit shall specify the inputs, outputs, biases, and power dissipation, as applicable, in accordance with the intent specified in method 1005 of MIL-STD-883. b. TA = +125°C, minimum. d. Test duration: 1,000 hours, except as permitted by method 1005 of MIL-STD-883.
STANDARD
SIZE
5962-90633 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 B 10 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
