Datasheet OP42 (Analog Devices) - 6
DescriptionHigh Speed, Fast Settling Precision Operational Amplifier
Pages / Page12 / 6 — STANDARD. 5962-88513. MICROCIRCUIT DRAWING
File Format / SizePDF / 162 Kb
STANDARD 5962-88513 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – Continued. Conditions 1/ Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits Unit unless otherwise specified subgroups type Min Max Slew rate 4/ SR AVCL = +1, RL = 2 kΩ 7 All 45 V/µs 8 40 Input offset voltage TCVOS TA = -55°C, +125°C 8 All 10 µV/°C temperature coefficient Settling time t 9 All 1.0 µs S See figure 2, TA = +25°C, 0.1 % for 10 V step 1/ Unless otherwise specified, VS = ±15 V, VCM = 0 V, RS = 50 Ω, and TA = TJ. 2/ Subgroup 3, if not tested, shall be guaranteed to the limits specified in table I herein. 3/ IVR is defined as the VCM range used for the CMR test. 4/ Slew rate may be specified separately for positive and negative going changes. 3.6 Certificate of compliance. For device classes Q and V, a certificate of compliance shall be required from a QML-38535 listed manufacturer in order to supply to the requirements of this drawing (see 6.6.1 herein). For device class M, a certificate of compliance shall be required from a manufacturer in order to be listed as an approved source of supply in MIL-HDBK-103 (see 6.6.2 herein). The certificate of compliance submitted to DLA Land and Maritime-VA prior to listing as an approved source of supply for this drawing shall affirm that the manufacturer's product meets, for device classes Q and V, the requirements of MIL- PRF-38535 and herein or for device class M, the requirements of MIL-PRF-38535, appendix A and herein. 3.7 Certificate of conformance. A certificate of conformance as required for device classes Q and V in MIL-PRF-38535 or for device class M in MIL-PRF-38535, appendix A shall be provided with each lot of microcircuits delivered to this drawing. 3.8 Notification of change for device class M. For device class M, notification to DLA Land and Maritime-VA of change of product (see 6.2 herein) involving devices acquired to this drawing is required for any change that affects this drawing. 3.9 Verification and review for device class M. For device class M, DLA Land and Maritime, DLA Land and Maritime 's agent, and the acquiring activity retain the option to review the manufacturer's facility and applicable required documentation. Offshore documentation shall be made available onshore at the option of the reviewer. 3.10 Microcircuit group assignment for device class M. Device class M devices covered by this drawing shall be in microcircuit group number 49 (see MIL-PRF-38535, appendix A).
STANDARD
SIZE
5962-88513 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 G
6
DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
