Datasheet OP400 (Analog Devices) - 5
DescriptionLow Offset, Low Power Quad Op Amp
Pages / Page12 / 5 — STANDARD. 5962-87771. MICROCIRCUIT DRAWING
File Format / SizePDF / 81 Kb
STANDARD 5962-87771 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions 1/ Test Symbol -55C  TA +125C Group A Device Limits Unit V subgroups type CC = 15 V unless otherwise specified Min Max Input offset voltage VIO 1 01 -150 +150 V 2, 3 -270 +270 M,D,P,L,R 1 -150 +150 Input offset current IIO VCM = 0 V 1 01 -1.0 +1.0 nA 2, 3 -2.5 +2.5  M,D,P,L,R 1 -2.5 +2.5 Input bias current IIB VCM = 0 V 1 01 -3.0 +3.0 nA 2, 3 -5.0 +5.0 M,D,P,L,R 1 -20.0 +20.0 Input voltage range +IVR 2/ 1, 2, 3 01 +12 V -IVR -12 Common mode rejection CMRR VCM = 12 V 1 01 120 dB ratio 2, 3 115 M,D,P,L,R 1 115  Power supply rejection ratio PSRR VCC = 3 V and 18 V 1 01 1.8 V/V 2, 3 3.2 M,D,P,L,R 1 3.2 Supply current ISY No load 3/ 1 01 2.9 mA 2, 3 3.1 M,D,P,L,R 1 3.1 Large signal voltage gain AVS VOUT = 10 V, RL = 2 k 4 01 2000 V/mV 5, 6 1000 M,D,P,L,R 4 2000 VOUT = 10 V, RL = 10 k 4 5000 5, 6 3000 M,D,P,L,R 4 5000 Output voltage swing +VOP RL = 2 k 4, 5, 6 01 +11 V M,D,P,L,R 4 +11 RL = 10 k 4,5,6 +12 M,D,P,L,R 4 +12 -VOP RL = 2 k 4,5,6 -11 M,D,P,L,R 4 -11 RL = 10 k 4,5,6 -12 M,D,P,L,R 4 -12 See footnotes at end of table.
STANDARD
SIZE
5962-87771 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 G 5 DSCC FORM 2234 APR 97
