DatasheetsDatasheet ADR225-KGD-CHIPS (Analog Devices)
Description | High Temperature, Low Drift, Micropower, 2.5V Reference |
Pages / Page | 6 / 1 — High Temperature, 2.5 V. Precision Voltage Reference. Known Good Die. … |
File Format / Size | PDF / 158 Kb |
High Temperature, 2.5 V. Precision Voltage Reference. Known Good Die. ADR225-KGD-CHIPS. FEATURES. METAL MASK DIE IMAGE
High Temperature, 2.5 V Precision Voltage Reference Known Good Die ADR225-KGD-CHIPS FEATURES METAL MASK DIE IMAGE Extreme high temperature operation NC −40°C to +210°C NC 1 V 8 7b OUT Temperature coefficient: 40 ppm/°C typical FORCE High output current: 10 mA Low supply current: 60 µA maximum V 2a S Initial accuracy: ±2.4% (±60 mV maximum) Low dropout voltage APPLICATIONS Downhole drilling and instrumentation V Avionics OUT 7a VS 2b SENSE Heavy industrial High temperature environments 6 NC GND 3 4 5 NC
001
NC
14153- Figure 1.
GENERAL DESCRIPTION
The ADR225-KGD-CHIPS is a precision 2.5 V band gap voltage The ADR225-KGD-CHIPS is a member of a growing series of reference specified for a high temperature operation of 210°C. It high temperature qualified products offered by Analog Devices, uses a micropower core topology and laser trimming of highly Inc. For a complete selection table of the available high temperature stable, thin film resistors to achieve a temperature coefficient of products, see the high temperature product list and qualification 80 ppm/°C (maximum) up to 210°C and an initial accuracy of data available at www.analog.com/hightemp. 2.4% (±60 mV maximum). A maximum operating current of Additional application and technical information can be found 60 µA and a low dropout voltage al ow the ADR225-KGD-CHIPS in the ADR225 data sheet. to function very wel in battery-powered equipment.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS METAL MASK DIE IMAGE GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
