Datasheet LTM8052, LTM8052A (Analog Devices) - 9
Description36VIN, 5A, 2-Quadrant CVCC Step-Down μModule Regulator
Pages / Page32 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 640 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Minimum Required Input Voltage. vs Load 24VOUT
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Minimum Required Input Voltage vs Load 24VOUT
LTM8052/LTM8052A
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Minimum Required Input Voltage Minimum Required Input Voltage Minimum Required Input Voltage vs Load 24VOUT vs Load –3.3VOUT vs Load –5VOUT
28.0 35 35 TO START TO START 30 TO RUN 30 TO RUN 27.5 25 25 27.0 20 20 15 15 26.5 INPUT VOLTAGE (V) INPUT VOLTAGE (V) 10 INPUT VOLTAGE (V) 10 26.0 5 5 25.5 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) 8052 G37 LOAD CURRENT (A) 8052 G38 8052 G39
Minimum Required Input Voltage Minimum Required Input Voltage Temperature Rise vs Load Current vs Load –8VOUT vs Load –12VOUT 2.5VOUT
30 30 60 TO START TO START 36VIN TO RUN TO RUN 24VIN 25 25 50 12VIN 6VIN 20 20 40 15 15 30 10 INPUT VOLTAGE (V) 10 INPUT VOLTAGE (V) 20 TEMPERATURE RISE (°C) 5 5 10 0 0 0 0 1 2 3 4 5 0 1 2 3 4 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8052 G40 8052 G41 8052 G42
Temperature Rise vs Load Current Temperature Rise vs Load Current Temperature Rise vs Load Current 3.3VOUT 5VOUT 8VOUT
60 70 90 36VIN 36VIN 36VIN 24VIN 24VIN 80 24VIN 50 12V 60 IN 12VIN 12VIN 6VIN 7VIN 70 50 40 60 40 50 30 30 40 20 30 20 TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) 20 10 10 10 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8052 G43 8052 G44 8052 G45 8052fg For more information www.linear.com/LTM8052 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photos Revision History Typical Application Related Parts
