Datasheet LTC4101 (Analog Devices) - 4
DescriptionSmart Battery Charger Controller
Pages / Page30 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 261 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC4101
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VDCIN = 20V, VDD = 3.3V, VBAT = 4V unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VBGATE at Shutdown ITGATE = 1μA 100 mV
AC Present Comparator
VACP DCDIV Threshold VDCDIV Rising from 1V to 1.4V l 1.14 1.20 1.26 V DCDIV Hysteresis 25 mV DCDIV Input Bias Current VDCDIV = 1.2V –1 1 μA ACP VOH IACP = –2mA 2 V ACP VOL IACP = 1mA 0.5 V DCDIV to ACP Delay VDCDIV = 1.3V 10 μs
SafetySignal Decoder
SafetySignal Trip (RES_COLD/RES_OR) RTHA = 1130Ω ±1%, CTH = 1nF (Note 6) l 95 100 105 kΩ RTHB = 54.9Ω ±1% SafetySignal Trip (RES_IDEAL/RES_COLD) RTHA = 1130Ω ±1%, CTH = 1nF (Note 6) l 28.5 30 31.5 kΩ RTHB = 54.9Ω ±1% SafetySignal Trip (RES_HOT/RES_IDEAL) RTHA = 1130Ω ±1%, CTH = 1nF (Note 6) l 2.85 3 3.15 kΩ RTHB = 54.9Ω ±1% SafetySignal Trip (RES_UR/RES_HOT) RTHA = 1130Ω ±1%, CTH = 1nF (Note 6) l 425 500 575 Ω RTHB = 54.9Ω ±1% Time Between SafetySignal Measurements DCDIV = 1.3V 32 ms DCDIV = 1V 250 ms
DACs
Charging Current Resolution Guaranteed Monotonic Above IMAX/16 10 Bits Charging Current Granularity RILIM = 0 1 mA RILIM = 10k ±1% 2 mA RILIM = 33k ±1% 4 mA RILIM = Open (or Short to VDD) 4 mA Wake-Up Charging Current (IWAKE-UP) All Values of RILIM 80 (Note mA All Values of RVLIM 5) Charging Current Limit RILIM = 0 (0-1A) 97.3 107.3 mV CSP – BAT Charging Current = 0x03FF (0x0400 Note 7) RILIM = 10k ±1% (0-2A) 97.3 107.3 mV Charging Current = 0x07FE (0x0800 Note 7) RILIM = 33k ±1% (0-3A) 72.3 82.3 mV Charging Current = 0x0BFC (0x0C00 Note 7) RILIM = 0pen (or Short to VDD) (0-4A) l 97.3 107.3 mV Charging Current = 0x0FFC (0x1000 Note 7) Charging Voltage Resolution Guaranteed Monotonic (2.9V ≤ VBAT ≤ 5.6V) 11 Bits Charging Voltage Granularity 16 mV Charging Voltage Limit RVLIM = 0 4.206 4.240 4.274 V Charging Voltage = 0x1090 (Note 7) RVLIM = 10k ±1% 4.270 4.304 4.338 V Charging Voltage = 0x10D0 (Note 7) RVLIM = 33k ±1% 4.397 4.432 4.467 V Charging Voltage = 0x1150 (Note 7) RVLIM = 100k ±1% 4.476 4.512 4.548 V Charging Voltage = 0x11A0 (Note 7) RVLIM = 0pen (or Short to VDD) 5.460 5.504 5.548 V Charging Voltage = 0x1580 (Note 7) 4101fa 4
