Datasheet LT1511 (Analog Devices) - 3
DescriptionConstant-Current/Constant-Voltage 3A Battery Charger with Input Current Limiting
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 149 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LT1511
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = 16V, VBAT = 8V, VMAX (maximum operating VCC) = 28V, RS2 = RS3 = 200
(see Block Diagram), VCLN = VCC. No load on any outputs unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Overall
Boost Pin Current VCC = 20V, VBOOST = 0V 0.1 10 µA VCC = 28V, VBOOST = 0V 0.25 20 µA 2V ≤ VBOOST – VCC < 8V (Switch ON) 6 9 mA 8V ≤ VBOOST – VCC ≤ 25V (Switch ON) 8 12 mA
Switch
Switch ON Resistance 8V ≤ VCC ≤ VMAX, ISW = 3A, VBOOST – VSW ≥ 2V ● 0.15 0.25 Ω ∆IBOOST/∆ISW During Switch ON VBOOST = 24V, ISW ≤ 3A 25 35 mA/A Switch OFF Leakage Current VSW = 0V, VCC ≤ 20V ● 2 100 µA 20V < VCC ≤ 28V ● 4 200 µA Minimum IPROG for Switch ON ● 2 4 20 µA Minimum IPROG for Switch OFF at VPROG ≤ 1V ● 1 2.4 mA Maximum VBAT for Switch ON ● VCC – 2 V
Current Sense Amplifier CA1 Inputs (Sense, BAT)
Input Bias Current ● – 50 – 125 µA Input Common Mode Low ● – 0.25 V Input Common Mode High ● VCC – 2 V SPIN Input Current – 100 – 200 µA
Reference
Reference Voltage (Note 3) RPROG = 4.93k, Measured at OVP with VA Supplying IPROG and Switch OFF 2.453 2.465 2.477 V Reference Voltage All Conditions of VCC, TJ > 0°C ● 2.441 2.489 V TJ < 0°C (Note 4) ● 2.43 2.489 V
Oscillator
Switching Frequency 180 200 220 kHz Switching Frequency All Conditions of VCC, TJ > 0°C ● 170 200 230 kHz TJ < 0°C ● 160 230 kHz Maximum Duty Cycle ● 85 % TA = 25°C 90 93 %
Current Amplifier CA2
Transconductance VC = 1V, IVC = ±1µA 150 250 550 µmho Maximum VC for Switch OFF ● 0.6 V IVC Current (Out of Pin) VC ≥ 0.6V 100 µA VC < 0.45V 3 mA 3
