Datasheet LT1004 (Analog Devices) - 3
DescriptionMicropower Voltage Reference
Pages / Page12 / 3 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 684 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LT1004
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. C, I SUFFIXES H SUFFIX SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VZ Reverse Breakdown Voltage IR = 100µA 1.231 1.235 1.239 2.480 2.500 2.520 V LT1004M: –55°C ≤ TA ≤ 125°C ● 1.220 1.230 1.245 2.460 2.500 2.535 V LT1004C: 0°C ≤ TA ≤ 70°C ● 1.225 1.235 1.245 2.470 2.500 2.530 V LT1004I: –40°C ≤ TA ≤ 85°C ● 1.220 1.230 1.245 2.460 2.500 2.530 V ∆VZ Average Temperature Coefficient IMIN ≤ IR ≤ 20mA (Note 3) 20 20 ppm/°C ∆Temp IMIN Minimum Operating Current ● 8 10 12 20 µA ∆VZ Reverse Breakdown Voltage IMIN ≤ IR ≤ 1mA 1.0 1.0 mV ∆I Change with Current ● 1.5 1.5 mV R 1mA ≤ IR ≤ 20mA 10 10 mV ● 20 20 mV rZ Reverse Dynamic Impedance IR = 100µA 0.2 0.6 0.2 0.6 Ω ● 1.5 1.5 Ω en Wide Band Noise (RMS) IR = 100µA, 10Hz ≤ f ≤ 10kHz 60 120 µV ∆VZ Long Term Stability IR = 100µA, TA = 25°C ± 0.1°C 20 20 ppm/kHr ∆Time
Note 1:
Note 2:
All specifications are for TA = 25°C unless otherwise noted. may cause permanent damage to the device. Exposure to any Absolute
Note 3:
Selected devices with guaranteed maximum temperature Maximum Rating condition for extended periods may affect device coefficient are available upon request. reliability and lifetime. For MIL-STD components, please refer to LTC883C data sheet for test listing and parameters. 1004fc For more information www.linear.com/LT1004 3
