Datasheet LTC6078, LTC6079 (Analog Devices)
DescriptionMicropower Precision, Dual/Quad CMOS Rail-to-Rail Input/Output Amplifiers
Pages / Page20 / 1 — FEATURES. DESCRIPTIO. Maximum Offset Voltage of 25µV (25°C). Maximum …
File Format / SizePDF / 344 Kb
FEATURES. DESCRIPTIO. Maximum Offset Voltage of 25µV (25°C). Maximum Offset Drift of 0.7µV/°C. Maximum Input Bias:. 1pA. (25°C). 50pA
Datasheet LTC6078, LTC6079 Analog Devices
LTC6078/LTC6079 Micropower Precision, Dual/Quad CMOS Rail-to-Rail Input/Output Amplifi ers
U FEATURES DESCRIPTIO
The LTC®6078/LTC6079 are dual/quad, low offset, low ■
noise operational amplifi ers with low power consumption ■
Maximum Input Bias:
and rail-to-rail input/output swing.
1pA (25°C)
Input offset voltage is trimmed to less than 25µV and the
50pA (≤85°C)
CMOS inputs draw less than 50pA of bias current. The low ■ Micropower: 54µA per Amp offset drift, excellent CMRR, and high voltage gain make ■ 95dB CMRR (Min) it a good choice for precision signal conditioning. ■ 100dB PSRR (Min) ■ Input Noise Voltage Density: 16nV/√Hz Each amplifi er draws only 54µA current on a 3V supply. The ■ Rail-to-Rail Inputs and Outputs micropower, rail-to-rail operation of the LTC6078/LTC6079 ■ 2.7V to 5.5V Operation Voltage is well suited for portable instruments and single supply ■ LTC6078 Available in 8-Lead MSOP and 10-Lead DFN applications. Packages; LTC6079 Available in 16-Lead SSOP and The LTC6078/LTC6079 are specifi ed on power supply DFN Packages voltages of 3V and 5V from –40 to 125°C. The dual am- plifi er LTC6078 is available in 8-lead MSOP and 10-lead
U
DFN packages. The quad amplifi er LTC6079 is available
APPLICATIO S
in 16-lead SSOP and DFN packages. ■ Photodiode Amplifi er , LT, LTC and LTM are registered trademarks of Linear Technology Corporation. ■ High Impedance Sensor Amplifi er All other trademarks are the property of their respective owners. Patent Pending. ■ Microvolt Accuracy Threshold Detection ■ Instrumentation Amplifi ers ■ Battery Powered Applications
U TYPICAL APPLICATIO Thermocouple Signal Conditioner VOS Distribution
14 LTC6078MS8 5V SMT V NORMALLY S = 3V 1/4W 12 V FLOATING CM = 0.5V 150k TA = 25°C + 10 0.1µF 1/2 OUT = 10mV/°C OMEGA LTC6078 0°C TO 500°C ±0.5°C 8 5TC-TT-K-30-36 – SMT 5V THERMOCOUPLE 1/4W 2.49M 1k 6 150k K 40.6µV/°C 4 LT1025 10k 100pF NUMBER OF AMPS OUT OF 200 5.6pF 2 60789 TA01a 0 AMPLIFIER PROTECTED TO ±190V, ACCIDENTAL CONTACT –11 –9 –7 –5 –3 –1 1 3 5 7 9 VOS (µV) 60789 TA01b 60789fa 1
