Datasheet LTC1992 (Analog Devices) - 6
DescriptionLow Power, Fully Differential Input/Output Amplifier/Driver Family
Pages / Page42 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 508 Kb
LTC1992 Family
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. +VS = 5V, –VS = 0V, VINCM = VOUTCM = VOCM = 2.5V, unless otherwise noted. VOCM is the voltage on the VOCM pin. VOUTCM is defined as (+VOUT + –VOUT)/2. VINCM is defined as (+VIN + –VIN)/2. VINDIFF is defined as (+VIN – –VIN). VOUTDIFF is defined as (+VOUT – –VOUT). Typical values are at TA = 25°C. Specifications apply to the LTC1992-5 only. LTC1992-5CMS8 LTC1992-5ISM8 LTC1992-5HMS8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
GDIFF Differential Gain 5 5 V/V Differential Gain Error l ±0.1 ±0.3 ±0.1 ±0.35 % Differential Gain Nonlinearity 50 50 ppm Differential Gain Temperature Coefficient l 3.5 3.5 ppm/°C en Input Referred Noise Voltage Density (Note 7) f = 1kHz 45 45 nV/√Hz RIN Input Resistance, Single-Ended +IN, –IN Pins l 22.5 30 37.5 22 30 38 kΩ VINCMR Input Signal Common Mode Range VS = 5V –0.1V to 3.9V –0.1V to 3.9V V CMRR Common Mode Rejection Ratio VINCM = –0.1V to 3.7V l 55 60 55 60 dB (Amplifier Input Referred) (Note 7) SR Slew Rate (Note 4) l 0.7 2 0.7 2 V/μs GBW Gain-Bandwidth Product fTEST = 180kHz 4 4 MHz
The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. +VS = 5V, –VS = 0V, VINCM = VOUTCM = VOCM = 2.5V, unless otherwise noted. VOCM is the voltage on the VOCM pin. VOUTCM is defined as (+VOUT + –VOUT)/2. VINCM is defined as (+VIN + –VIN)/2. VINDIFF is defined as (+VIN – –VIN). VOUTDIFF is defined as (+VOUT – –VOUT). Typical values are at TA = 25°C. Specifications apply to the LTC1992-10 only. LTC1992-10CMS8 LTC1992-10ISM8 LTC1992-10HMS8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
GDIFF Differential Gain 10 10 V/V Differential Gain Error l ±0.1 ±0.3 ±0.1 ±0.35 % Differential Gain Nonlinearity 50 50 ppm Differential Gain Temperature Coefficient l 3.5 3.5 ppm/°C en Input Referred Noise Voltage Density (Note 7) f = 1kHz 45 45 nV/√Hz RIN Input Resistance, Single-Ended +IN, –IN Pins l 11.3 15 18.8 11 15 19 kΩ VINCMR Input Signal Common Mode Range VS = 5V –0.1V to 3.8V –0.1V to 3.8V V CMRR Common Mode Rejection Ratio VINCM = –0.1V to 3.7V l 55 60 55 60 dB (Amplifier Input Referred) (Note 7) SR Slew Rate (Note 4) l 0.7 2 0.7 2 V/μs GBW Gain-Bandwidth Product fTEST = 180kHz 4 4 MHz
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings LTC1992H/LTC1992-XH are guaranteed functional over the extended may cause permanent damage to the device. Exposure to any Absolute operating temperature of –40°C to 125°C. Maximum Rating condition for extended periods may affect device
Note 6:
The LTC1992C/LTC1992-XC are guaranteed to meet the specified reliability and lifetime. performance limits over the 0°C to 70°C temperature range and are
Note 2:
Output load is connected to the midpoint of the +VS and –VS designed, characterized and expected to meet the specified performance potentials. Measurement is taken single-ended, one output loaded at a limits over the –40°C to 85°C temperature range but are not tested or QA time. sampled at these temperatures. The LTC1992I/LTC1992-XI are guaranteed
Note 3:
A heat sink may be required to keep the junction temperature to meet the specified performance limits over the –40°C to 85°C below the absolute maximum when the output is shorted indefinitely. temperature range. The LTC1992H/LTC1992-XH are guaranteed to meet the
Note 4:
Differential output slew rate. Slew rate is measured single ended specified performance limits over the –40°C to 125°C temperature range. and doubled to get the listed numbers.
Note 7:
Differential offset voltage, differential offset voltage drift, CMRR,
Note 5:
The LTC1992C/LTC1992-XC/LTC1992I/LTC1992-XI are guaranteed noise voltage density and PSRR are referred to the internal amplifier’s functional over an operating temperature of –40°C to 85°C. The input to allow for direct comparison of gain blocks with discrete amplifiers. 1992fb 6
