Datasheet LT1464, LT1465 (Analog Devices)
DescriptionDual/Quad Micropower, 1MHz C-Load Picoampere Bias Current JFET Input Op Amps
Pages / Page12 / 1 — FEATURES. DESCRIPTION. Input Bias Current:. 2pA Max (LT1464A). 20pA Max …
File Format / SizePDF / 285 Kb
FEATURES. DESCRIPTION. Input Bias Current:. 2pA Max (LT1464A). 20pA Max (LT1464, LT1465). Supply Current per Amplifier: 200. A Max
Datasheet LT1464, LT1465 Analog Devices
LT1464/LT1465 Dual/Quad Micropower, 1MHz C-Load Picoampere Bias Current JFET Input Op Amps
U FEATURES DESCRIPTION
Input Bias Current:
The LT®1464 (dual) and LT1465 (quad) are the first
2pA Max (LT1464A)
micropower op amps (200µA max per amp) to offer
picoampere input bias currents (500fA typ) and unity-gain ■
µ
A Max
stability for capacitive loads up to 10nF. The output can ■ Gain Bandwidth Product: 1MHz Typ swing a 10k load to within 1.5V of either supply, just like ■ Slew Rate: 0.9V/µs Typ op amps that require an order of magnitude more supply ■ Input Common Mode Range Includes Positive Rail current. This unique combination of performance makes ■ Unity-Gain Stable for C-LoadTM Up to 10nF the LT1464/LT1465 ideal over a wide range of input and ■ Open-Loop Gain: 1 Million Typ output impedances. ■ Guaranteed Specs with ±5V, ±15V Supplies In the design and testing of the LT1464/LT1465, particular ■ Guaranteed Matching Specifications emphasis has been placed on optimizing performance in ■ Standard Pinout: SO-8, SO-14 Package the low cost SO-8 (dual) and 14-lead SO (quad) package for
U
±15V and ±5V supplies. The input common mode range
includes the positive rail. Slew rate (0.5V/µs min) and gain ■ Battery-Powered Systems bandwidth product (650kHz min) are 100% tested. A full ■ Photocurrent Amplifiers set of matching specifications is also provided. ■ Low Frequency, Micropower Active Filters , LTC and LT are registered trademarks of Linear Technology Corporation. ■ Low Droop Track-and-Hold Circuits C-Load is a trademark of Linear Technology Corporation.
U TYPICAL APPLICATION Micropower Low Droop Track-and-Hold/Peak Detector
V+ 1/4 LTC201 13 15 C1
Small-Signal Response, CLOAD = 10nF
16 10nF A POLYSTYRENE 1 MCT2 5 4 14 V– V+ 5 + 2 2 6 4 – 8 7 R1* 1 1/2 LT1464 1/2 LT1464 VOUT 6 3 IN – 1 MCT2 5 + 4 1/4 LTC201 2 V– LT1464 • TA01 1 B 0.5pA 2 6 4 TYPICAL DROOP = = 0.05mV/s 10nF TOTAL SUPPLY CURRENT = 460 µA MAX 1464 • TA02 5 3 AV = 1 * R1 = 600 Ω FOR ±15V SUPPLIES VS = ±5V, ±15V R1 = 0 Ω FOR ±5V SUPPLIES CL = 10nF
FUNCTION MODE IN A IN B MODE IN A IN B
Track-and-Hold Track 0 0 Hold 1 1 Positive Peak Detector Reset 0 0 Store 0 1 Negative Peak Detector Reset 0 0 Store 1 0 LTC201 switch is open for logic "1". 1
