Datasheet LTC6416 (Analog Devices) - 4
Description2GHz Low Noise Differential 16-Bit ADC Buffer
Pages / Page20 / 4 — 3.3V ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
File Format / SizePDF / 401 Kb
3.3V ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full
3.3V ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full
LTC6416
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3.3V, GND = 0V, No RLOAD, CLOAD = 6pF. VCM = 1.25V, CLHI = V+, CLLO = 0V unless otherwise noted. VINCM is defi ned as (IN+ + IN–)/2. VOUTCM is defi ned as (OUT+ + OUT–)/2. VINDIFF is defi ned as (IN+ – IN–). VOUTDIFF is defi ned as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristics
GDIFF Differential Gain VINDIFF = ±1.2V –0.3 –0.15 0 dB l –0.4 0 dB TCGDIFF Differential Gain Temperature Coeffi cient l –0.00033 dB/°C VOUTDIFF Differential Output Voltage Swing VINDIFF = ±2.3V 3.5 4 VP-P l 3.2 VP-P VOUTMIN Output Voltage Swing Low Single-Ended Measurement of OUT+, 0.2 0.3 V OUT–. VINDIFF = ±2.3V l 0.35 V VOUTMAX Output Voltage Swing High Single-Ended Measurement of OUT+, 2.05 2.2 V OUT–. VINDIFF = ±2.3V l 1.95 V IOUT Output Current Drive (Note 4) Single-Ended Measurement of OUT+, OUT– l ±20 mA VOS Differential Input Offset Voltage IN+ = IN– = 1.25V, VOS = VOUTDIFF/ –5 –0.1 5 mV GDIFF l –10 10 mV TCVOS Differential Input Offset Voltage Drift l 1 μV/°C VIOCM Common Mode Offset Voltage, Input to VOUTCM – VINCM –65 –40 –15 mV Output l –75 –5 mV IVRMIN Input Voltage Range, IN+, IN– Defi ned by Output Voltage Swing Test l 0.1 V (Minimum) (Single-Ended) IVRMAX Input Voltage Range, IN+, IN– Defi ned by Output Voltage Swing Test l 2.4 V (Maximum) (Single-Ended) IB Input Bias Current, IN+, IN– IN+ = IN– = 1.25V l –15 –4 15 μA RINDIFF Differential Input Resistance VINDIFF = ±1.2V l 9 12 15 kΩ CINDIFF Differential Input Capacitance 1 pF RINCM Input Common Mode Resistance IN+ = IN– = 0.65V to 1.85V 6 kΩ CMRR Common Mode Rejection Ratio IN+ = IN– = 0.65V to 1.85V = ΔVINCM, 63.5 83 dB CMRR = (VOUTDIFF/GDIFF/ΔVINCM) l 59.6 dB eN Input Noise Voltage Density f = 100kHz 1.8 nV/√Hz iN Input Noise Current Density f = 100kHz 6.5 pA/√Hz
Output Common Mode Voltage Control
GCM VCM Pin Common Mode Gain VCM = 0.65V to 1.85V l 0.9 0.96 1.05 V/V VINCMDEFAULT Default Input Common Mode Voltage VINCM. IN+, IN–, VCM Pin Floating l 1.2 1.28 1.35 V VOS (VCM – VINCM) Offset Voltage, VCM to VINCM VCM – VINCM, VCM = 1.25V l –70 –26 70 mV VOUTCMDEFAULT Default Output Common Mode Voltage Inputs Floating, VCM Pin Floating l 1.15 1.24 1.35 V VOS (VCM – VOUTCM) Offset Voltage, VCM to VOUTCM VCM – VOUTCM, VCM = 1.25V l –60 14 60 mV VOUTCMMIN Output Common Mode Voltage VCM = 0.1V 0.34 0.5 V (Minimum) l 0.55 V VOUTCMMAX Output Common Mode Voltage VCM = 2.4V 2.05 2.16 V (Maximum) l 2 V VCMDEFAULT VCM Pin Default Voltage l 1.2 1.25 1.3 V RVCM VCM Pin Input Resistance l 2.5 3.8 5.1 kΩ CVCM VCM Pin Input Capacitance 1 pF IBVCM VCM Pin Bias Current VCM = 1.25V l –10 0.2 10 μA 6416f 4
