Datasheet LT6600-5 (Analog Devices) - 2
DescriptionVery Low Noise, Differential Amplifier and 5MHz Lowpass Filter
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 158 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT6600-5
Total Supply Voltage ...11V TOP VIEW Input Current (Note 8) ..±10mA IN– 1 8 IN+ Operating Temperature Range (Note 6).. –40°C to 85°C V 2 7 V OCM MID Specifi ed Temperature Range (Note 7) .. –40°C to 85°C V+ 3 6 V– Junction Temperature ... 150°C OUT+ 4 5 OUT– Storage Temperature Range ...– 65°C to 150°C S8 PACKAGE Lead Temperature (Soldering, 10 sec) .. 300°C 8-LEAD PLASTIC SO TJMAX = 150°C, θJA = 100°C/W
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT6600CS8-5#PBF LT6600CS8-5#TRPBF 66005 8-Lead Plastic SO –40°C to 85°C LT6600IS8-5#PBF LT6600IS8-5#TRPBF 6600I5 8-Lead Plastic SO –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT6600CS8-5 LT6600CS8-5#TR 66005 8-Lead Plastic SO –40°C to 85°C LT6600IS8-5 LT6600IS8-5#TR 6600I5 8-Lead Plastic SO –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Unless otherwise specifi ed VS = 5V (V+ = 5V, V– = 0V), RIN = 806
Ω
, and RLOAD = 1k. PARAMETER CONDITIONS MIN TYP MAX UNITS
Filter Gain, VS = 3V VIN = 2VP-P, fIN = DC to 260kHz – 0.5 0 0.5 dB VIN = 2VP-P, fIN = 500k (Gain Relative to 260kHz) l –0.15 0 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –0.4 – 0.1 0.3 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l – 0.7 – 0.1 0.6 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l –1.1 –0.2 0.8 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l – 28 –25 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l –44 dB Filter Gain, VS = 5V VIN = 2VP-P, fIN = DC to 260kHz – 0.5 0 0.5 dB VIN = 2VP-P, fIN = 500k (Gain Relative to 260kHz) l – 0.15 0 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –0.4 – 0.1 0.3 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l – 0.7 –0.1 0.6 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l – 1.1 –0.2 0.8 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l – 28 –25 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l – 44 dB Filter Gain, VS = ±5V VIN = 2VP-P, fIN = DC to 260kHz – 0.6 –0.1 0.4 dB 66005fb 2
