Datasheet LT1168 (Analog Devices) - 5
DescriptionLow Power, Single Resistor Gain Programmable, Precision Instrumentation Amplifier
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 353 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the –40. temperature range. VS =
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the –40 temperature range VS =
LT1168
C
TA
85
C temperature range. VS =
15V, VCM = 0V, RL = 10k unless otherwise noted. (Note 5) LT1168AI LT1168I SYMBOL PARAMETER CONDITIONS (Note 6) MIN TYP MAX MIN TYP MAX UNITS
VOST Total Input Referred Offset Voltage VOST = VOSI + VOSO/G VOSI Input Offset Voltage ● 20 75 25 100 µV VOSIH Input Offset Voltage Hysteresis (Notes 7, 10) ● 3.0 3.0 µV VOSO Output Offset Voltage ● 180 500 200 600 µV VOSOH Output Offset Voltage Hysteresis (Notes 7, 10) ● 30 30 µV VOSI/T Input Offset Drift (RTI) (Note 9) ● 0.05 0.3 0.06 0.4 µV/°C VOSO/T Output Offset Drift (Note 9) ● 0.8 5 1 6 µV/°C IOS Input Offset Current ● 110 550 120 700 pA IOS/T Input Offset Current Drift ● 0.3 0.3 pA/°C IB Input Bias Current ● 120 500 220 800 pA IB/T Input Bias Current Drift ● 1.4 1.4 pA/°C VCM Input Voltage Range VS = ±2.3V to ±5V ● –VS + 2.1 +VS – 1.3 –VS + 2.1 +VS – 1.3 V VS = ±5V to ±18V ● –VS + 2.1 +VS – 1.4 –VS + 2.1 +VS – 1.4 V CMRR Common Mode 1k Source Imbalance, Rejection Ratio VCM = 0V to ±10V G = 1 ● 86 90 81 90 dB G = 10 ● 98 105 95 105 dB G = 100 ● 114 118 112 118 dB G = 1000 ● 116 133 112 133 dB PSRR Power Supply VS = ±2.3V to ±18V Rejection Ratio G = 1 ● 100 112 95 112 dB G = 10 ● 120 125 115 125 dB G = 100 ● 125 132 120 132 dB G = 1000 ● 128 140 125 140 dB IS Supply Current ● 420 650 420 650 µA VOUT Output Voltage Swing VS = ±2.3V to ±5V ● –VS + 1.4 +VS – 1.3 –VS + 1.4 +VS – 1.3 V VS = ±5V to ±18V ● –VS + 1.6 +VS – 1.5 –VS + 1.6 +VS – 1.5 V IOUT Output Current ● 15 22 15 22 mA SR Slew Rate ● 0.22 0.41 0.22 0.42 V/µs VREF Voltage Range (Note 9) ● –VS + 1.6 +VS – 1.6 –VS + 1.6 +VS – 1.6 V
Note 1:
Note 6:
Typical parameters are defined as the 60% of the yield parameter may cause permanent damage to the device. Exposure to any Absolute distribution. Maximum Rating condition for extended periods may affect device
Note 7:
Does not include the tolerance of the external gain resistor RG. reliability and lifetime.
Note 8:
This parameter is measured in a high speed automatic tester that
Note 2:
If the input voltage exceeds the supplies, the input current should does not measure the thermal effects with longer time constants. The be limited to less than 20mA. magnitude of these thermal effects are dependent on the package used,
Note 3:
A heat sink may be required to keep the junction temperature heat sinking and air flow conditions. below absolute maximum.
Note 9:
This parameter is not 100% tested.
Note 4:
The LT1168AC/LT1168C are guaranteed functional over the
Note 10:
Hysteresis in offset voltage is created by package stress that operating temperature range of – 40°C and 85°C. differs depending on whether the IC was previously at a higher or lower
Note 5:
The LT1168AC/LT1168C are guaranteed to meet specified temperature. Offset voltage hysteresis is always measured at 25°C, but performance from 0°C to 70°C. The LT1168AC/LT1168C are designed, the IC is cycled to 85°C I-grade (or 70°C C-grade) or – 40°C I-grade characterized and expected to meet specified performance from – 40°C (0°C C-grade) before successive measurement. 60% of the parts will to 85°C but are not tested or QA sampled at these temperatures. The pass the typical limit on the data sheet. LT1168AI/LT1168I are guaranteed to meet specified performance from – 40°C to 85°C. 1168fa 5
