Datasheet LT6220, LT6221, LT6222 (Analog Devices) - 10
DescriptionSingle/Dual/Quad 60MHz, 20V/µs, Low Power, Rail-to-Rail Input and Output Precision Op Amps
Pages / Page22 / 10 — Typical perForMance characTerisTics. Output Saturation Voltage. Output …
File Format / SizePDF / 373 Kb
Typical perForMance characTerisTics. Output Saturation Voltage. Output Short-Circuit Current. vs Load Current (Output High)
Typical perForMance characTerisTics Output Saturation Voltage Output Short-Circuit Current vs Load Current (Output High)
LT6220/LT6221/LT6222
Typical perForMance characTerisTics Output Saturation Voltage Output Short-Circuit Current vs Load Current (Output High) Minimum Supply Voltage vs Power Supply Voltage
10 0.6 70 VS = 5V, 0V 60 TA = 25°C 0.4 50 TA = 125°C 40 1 SINKING 30 T 0.2 A = –55°C TA = –55°C 20 T 10 0.1 TA = 125°C 0 A = 25°C 0 TA = 125°C –10 TA = 25°C –0.2 –20 –30 0.01 TA = –55°C SOURCING –40 –0.4 OUTPUT SATURATION VOLTAGE (V) TA = –55°C CHANGE IN OFFSET VOLTAGE (mV) –50 OUTPUT SHORT-CIRCUIT CURRENT (mA) –60 TA = 125°C TA = 25°C 0.001 –0.6 –70 0.01 0.1 1 10 100 0 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 2 2.5 3 3.5 4 4.5 5 LOAD CURRENT (mA) TOTAL SUPPLY VOLTAGE (V) POWER SUPPLY VOLTAGE (±V) 622012 G10 622012 G11 622012 G12
Open-Loop Gain Open-Loop Gain Open-Loop Gain
1000 1000 1000 VS = 3V, 0V VS = 5V, 0V VS = ±5V 800 RL TO GND 800 RL TO GND 800 RL TO GND 600 600 600 400 400 400 200 200 200 RL = 1k RL = 1k RL = 1k 0 0 0 –200 –200 RL = 100Ω –200 –400 –400 –400 R RL = 100Ω –600 L = 100Ω –600 –600 CHANGE IN OFFSET VOLTAGE (µV) CHANGE IN OFFSET VOLTAGE (µV) CHANGE IN OFFSET VOLTAGE (µV) –800 –800 –800 –1000 –1000 –1000 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 6 –5 –4 –3 –2 –1 0 1 2 3 4 5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 622012 G13 622012 G14 622012 G15
Offset Voltage vs Output Current Warm-Up Drift vs Time Input Noise Voltage vs Frequency
2.0 10 40 VS = ±5V VS = 5V, 0V 1.5 8 35 6 ) 1.0 30 4 Hz 0.5 2 LT6222 LT6220 LT6221 25 T GN16 SOT5 A = –55°C TA = 25°C S8 0 0 VS = ±2.5V VS = ±2.5V V 20 S = ±2.5V NPN ACTIVE –0.5 –2 15 VCM = 4.25V TA = 125°C –4 –1.0 NOISE VOLTAGE (nV/√ 10 –6 LT6222 LT6220 LT6221 PNP ACTIVE CHANGE IN OFFSET VOLTAGE (mV) –1.5 CHANGE IN OFFSET VOLTAGE (µV) GN16 V –8 SOT5 S8 5 CM = 2.5V VS = ±5V VS = ±5V VS = ±5V –2.0 –10 0 –75 –60 –45 –30 –15 0 15 30 45 60 75 0 5 10 15 20 25 30 35 40 45 50 0.01 0.1 1 10 100 OUTPUT CURRENT (mA) TIME AFTER POWER-UP (SECONDS) FREQUENCY (kHz) 622012 G18 622012 G16 622012 G17 622012fc 10 For more information www.linear.com/LT6220/LT6221/LT6222 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
