Datasheet LT1803, LT1804, LT1805 (Analog Devices) - 6
DescriptionSingle/Dual/Quad 100V/µs, 85MHz, Rail-to-Rail Input and Output Op Amps
Pages / Page20 / 6 — ELECTRICAL CHARACTERISTICS TA = 25. C, VS =. 5V, VCM = 0V, VOUT = 0V, …
File Format / SizePDF / 411 Kb
ELECTRICAL CHARACTERISTICS TA = 25. C, VS =. 5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP
ELECTRICAL CHARACTERISTICS TA = 25 C, VS = 5V, VCM = 0V, VOUT = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP
LT1803/LT1804/LT1805
C, VS =
5V, VCM = 0V, VOUT = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = –5V 0.35 2.5 mV VCM = –5V (DD Package) 1.50 3.5 mV VCM = –5V (SOT-23 Package) 1.50 6 mV VCM = 5V 1.50 8 mV ∆VOS Input Offset Shift VCM = –5V to 3V 0.3 1 mV Input Offset Voltage Match VCM = –5V 0.5 4 mV (Channel-to-Channel) (Note 9) VCM = –5V (DD Package) 1 5.5 mV IB Input Bias Current VCM = –4V 125 750 nA VCM = 5V 2.5 5.5 µA Input Bias Current Match VCM = –4V 150 1250 nA (Channel-to-Channel) (Note 9) VCM = 5V 150 1500 nA IOS Input Offset Current VCM = –4V 100 1000 nA VCM = 5V 50 1000 nA Input Noise Voltage 0.1Hz to 10Hz 4 µVP-P en Input Noise Voltage Density f = 10kHz 21 nV/√Hz in Input Noise Current Density f = 10kHz 2.5 pA/√Hz CIN Input Capacitance f = 100kHz 2 pF AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k 20 55 V/mV VO = –1.5V to 1.5V, RL = 100Ω 2 5 V/mV CMRR Common Mode Rejection Ratio VCM = –5V to 3V 78 96 dB CMRR Match (Channel-to-Channel) (Note 9) VCM = –5V to 3V 72 96 dB Input Common Mode Range V – + S ␣ ␣ VS V PSRR Power Supply Rejection Ratio V + – + S = 2.5V to 10V, VS = 0V, VOUT = VS /2 68 90 dB PSRR Match (Channel-to-Channel) (Note 9) V + – + S = 2.5V to 10V, VS = 0V, VOUT = VS /2 62 90 dB VOL Output Voltage Swing Low (Note 7) No Load 17 60 mV ISINK = 5mA 85 150 mV ISINK = 15mA 200 300 mV VOH Output Voltage Swing High (Note 7) No Load 17 60 mV ISOURCE = 5mA 125 250 mV ISOURCE = 15mA 350 600 mV ISC Short-Circuit Current (Note 3) 25 50 mA IS Supply Current per Amplifier 2.5 3 mA GBW Gain Bandwidth Product Frequency = 2MHz, RL = 1k 83 MHz SR Slew Rate AV = –1, RL = 1k, VO = ±4V 88 V/µs Measured at VO = ±2V FPBW Full Power Bandwidth (Note 10) VO = 8VP-P, AV = –1, RL = 1k 4 MHz HD Harmonic Distortion AV = 1, RL = 1k, VO = 2VP-P, fC = 1MHz –75 dBc tS Settling Time 0.01%, VSTEP = 5V, AV = 1, RL = 1k 500 ns ∆G Differential Gain (NTSC) AV = 2, RL = 150Ω 0.75 % ∆θ Differential Phase (NTSC) AV = 2, RL = 150Ω 0.8 Deg 180345f 6
