Datasheet LT1800 (Analog Devices) - 2
Description80MHz, 25V/µs Low Power Rail-to-Rail Input and Output Precision Op Amp
Pages / Page18 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 285 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT1800
Total Supply Voltage (V – + S to VS ) ..12.6V Specifi ed Temperature Range (Note 5) .. –40°C to 85°C Input Current (Note 2) ..±10mA Junction Temperature ... 150°C Output Short-Circuit Duration (Note 3) .. Indefi nite Storage Temperature Range ... –65°C to 150°C Operating Temperature Range (Note 4).. –40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW NC 1 8 NC – V + OUT 1 5 VS –IN 2 7 V + S + V – S 2 + – +IN 3 6 VOUT +IN 3 4 –IN V – S 4 5 NC S5 PACKAGE S8 PACKAGE 5-LEAD PLASTIC TSOT-23 8-LEAD PLASTIC SO TJMAX = 150°C, θJA = 250°C/W TJMAX = 150°C, θJA = 190°C/W
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1800CS8#PBF LT1800CS8#TRPBF 1800 8-Lead Plastic SO 0°C to 70°C LT1800IS8#PBF LT1800IS8#TRPBF 1800I 8-Lead Plastic SO –40°C to 85°C LT1800CS5#PBF LT1800CS5#TRPBF LTRN 5-Lead Plastic TSOT-23 0°C to 70°C LT1800IS5#PBF LT1800IS5#TRPBF LTRP 5-Lead Plastic TSOT-23 –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS TA = 25°C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = 0V 75 350 μV VCM = 0V (SOT-23) 300 750 μV VCM = VS 0.5 3 mV VCM = VS (SOT-23) 0.7 3.5 mV ΔVOS Input Offset Shift VCM = 0V to VS – 1.5V 20 180 μV IB Input Bias Current VCM = 1V 25 250 nA VCM = VS 500 1500 nA IOS Input Offset Current VCM = 1V 25 200 nA VCM = VS 25 200 nA Input Noise Voltage 0.1Hz to 10Hz 1.4 μVP-P 1800fa 2
