Datasheet LT1126, LT1127 (Analog Devices) - 4
DescriptionDual/Quad Decompensated Low Noise, High Speed Precision Op Amps
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 282 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LT1126/LT1127
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at VS =
15V, 0
C
TA
70
C, unless otherwise noted. LT1126AC LT1126C LT1127AC LT1127C SYMBOL PARAMETER CONDITIONS (Note 2) MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage LT1126 ● 35 120 45 170 µV LT1127 ● 40 140 50 210 µV ∆VOS/∆T Average Input Offset Voltage Drift (Note 5) ● 0.3 1.0 0.4 1.5 µV/°C IOS Input Offset Current LT1126 ● 6 25 7 35 nA LT1127 ● 7 35 8 45 nA IB Input Bias Current ● ± 8 ± 35 ± 9 ± 45 nA VCM Input Voltage Range ● ± 11.5 ± 12.4 ± 11.5 ± 12.4 V CMRR Common Mode Rejection Ratio VCM = ±11.5V ● 109 125 102 122 dB PSRR Power Supply Rejection Ratio VS = ±4V to ±18V ● 112 125 107 122 dB AVOL Large Signal Voltage Gain RL ≥ 10kΩ, VO = ±10V ● 4.0 15.0 2.5 14.0 V/µV RL ≥ 2kΩ, VO = ±10V ● 1.5 3.5 1.0 2.5 V/µV VOUT Maximum Output Voltage Swing RL ≥ 2kΩ ● ± 12.5 ± 13.7 ± 12.0 ± 13.7 V SR Slew Rate RL ≥ 2kΩ (Notes 3, 7) ● 7.5 10.5 7.3 10.5 V/µs IS Supply Current Per Amplifier ● 2.7 3.3 2.7 3.3 mA
The
15V,
40
C
TA
85
C, unless otherwise noted. (Note 10) LT1126AC LT1126C LT1127AC LT1127C SYMBOL PARAMETER CONDITIONS (Note 2) MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage LT1126 ● 40 140 50 200 µV LT1127 ● 45 160 55 240 µV ∆VOS/∆T Average Input Offset Voltage Drift (Note 5) ● 0.3 1.0 0.4 1.5 µV/°C IOS Input Offset Current LT1126 ● 15 40 17 55 nA LT1127 ● 15 50 17 65 nA IB Input Bias Current ● ± 15 ± 50 ± 17 ± 65 nA VCM Input Voltage Range ● ± 11.4 ± 12.2 ± 11.4 ± 12.2 V CMRR Common Mode Rejection Ratio VCM = ±11.4V ● 107 124 101 121 dB PSRR Power Supply Rejection Ratio VS = ± 4V to ±18V ● 111 124 106 121 dB AVOL Large Signal Voltage Gain RL ≥ 10kΩ, VO = ±10V ● 3.5 12.0 2.2 12.0 V/µV RL ≥ 2kΩ, VO = ±10V ● 1.2 3.2 0.8 2.3 V/µV VOUT Maximum Output Voltage Swing RL ≥ 2kΩ ● ± 12.5 ± 13.6 ± 12.0 ± 13.6 V SR Slew Rate RL ≥ 2kΩ (Note 7) ● 7.3 10.2 7.1 10.2 V/µs IS Supply Current Per Amplifier ● 2.8 3.4 2.8 3.4 mA
Note 1:
Note 7:
Slew rate is measured in AV = –10; input signal is ±1V, output of a device may be impaired. measured at ±5V.
Note 8:
0.1Hz to 10Hz noise can be inferred from the 10Hz noise voltage
Note 2:
Typical parameters are defined as the 60% yield of parameter density test. See the test circuit and frequency response curve for 0.1Hz to distributions of individual amplifiers; i.e., out of 100 LT1127s (or 100 10Hz tester in the Applications Information section of the LT1007 or LT1126s) typically 240 op amps (or 120) will be better than the indicated LT1028 datasheets. specification.
Note 9:
This parameter is guaranteed but not tested.
Note 3:
This parameter is 100% tested for each individual amplifier.
Note 10:
The LT1126/LT1127 are designed, characterized and expected to
Note 4:
This parameter is sample tested only. meet these extended temperature limits, but are not tested at –40°C and at
Note 5:
This parameter is not 100% tested. 85°C. Guaranteed I grade parts are available. Consult factory.
Note 6:
The inputs are protected by back-to-back diodes. Current limiting resistors are not used in order to achieve low noise. If differential input voltage exceeds ±1.4V, the input current should be limited to 25mA. 11267fa 4
