Datasheet LTC1541, LTC1542 (Analog Devices) - 6
DescriptionMicropower Op Amp, Comparator and Reference
Pages / Page12 / 6 — ELECTRICAL CHARACTERISTICS The
File Format / SizePDF / 267 Kb
LTC1541/LTC1542
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = 3V, VSS = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISOURCE Output Source Current 0.6 0.95 mA ● 0.4 mA ISINK Output Sink Current 1.2 1.8 mA ● 0.8 mA en Input Noise Voltage fO = 0.1Hz to 10Hz 3 µVP-P
Note 1:
Note 6:
The θJA specified for the DD package is with minimal PCB heat of the device may be impaired. spreading metal. Using expanded metal area on all layers of a board reduces this value.
Note 2:
Supply current is tested with COMPIN+ = (REF – 100mV) for LTC1541 and COMPIN+ = 0V, COMPIN– = 100mV for LTC1542.
Note 7:
The LTC1541C/LTC1541I and LTC1542C/LTC1542I are guaranteed functional over the operating temperature range of –40
Note 3:
Input offset voltage is defined as the center of the input referred °C to 85 hysteresis, V °C. CM = REF (LTC1541). VCM = 1/2 VCC (LTC1542).
Note 8:
The LTC1541C and LTC1542C are guaranteed to meet specified
Note 4:
Trip point is defined as the differential input voltage required to performance from 0 make the comparator output change state. The difference between upper °C to 70°C. The LTC1541C and LTC1542C are designed, characterized and expected to meet performance from –40 and lower trip point is equal to the width of the input referred hysteresis, °C to 85 V °C, but are not tested or QA sampled at these temperatures. The CM = REF (LTC1541). VCM = 1/2 VCC (LTC1542). LTC1541I and LTC1542I are guaranteed to meet specified performance
Note 5:
The input leakage current is measured for COMPIN+ at 0V from –40°C to 85°C. (LTC1541) and COMPIN+ = COMPIN– = 0V (LTC1542).
W U TYPICAL PERFOR A CE CHARACTERISTICS Reference Output Voltage vs Supply Current vs Supply Voltage Supply Current vs Temperature Load Current
10 10 1.205 V V 9 NONINVERTING CC = 5V 1.204 CC = 5V 9 V V VSS = GND SS = GND 8 SS = GND 1.203 AMPIN+ = V AMPIN– = AMPOUT SOURCING CC /2 8 µA) CURRENT 7 µA) AMPIN+ = 2.5V 1.202 7 6 1.201 5 6 1.200 4 1.199 5 3 1.198 SUPPLY CURRENT ( SUPPLY CURRENT ( 4 2 1.197 SINKING CURRENT 3 REFERENCE OUTPUT VOLTAGE (V) 1 1.196 0 2 1.195 2 3 4 5 6 7 8 9 10 11 12 –50 –25 0 25 50 75 100 125 1 10 100 1000 10000 SUPPLY VOLTAGE (V) TEMPERATURE (°C) LOAD CURRENT (µA) 1541/42 TPC03 1541/42 TPC01 1541/42 TPC02 15412fd 6
