Datasheet LT1466L, LT1467L (Analog Devices) - 4
DescriptionMicropower Dual/Quad Precision Rail-to-Rail Input and Output Op Amps
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS. TA = 25. C, VS =. 5V, VCM = VO = 0V, unless …
File Format / SizePDF / 249 Kb
ELECTRICAL CHARACTERISTICS. TA = 25. C, VS =. 5V, VCM = VO = 0V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX
ELECTRICAL CHARACTERISTICS TA = 25 C, VS = 5V, VCM = VO = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP MAX
LT1466L/LT1467L
C, VS =
5V, VCM = VO = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V + 120 475 µV VCM = V– 120 475 µV ∆VOS Input Offset Voltage Shift VCM = V – to V + 80 390 µV Input Offset Voltage Match VCM = V –, V + (Notes 3, 4) 150 685 µV (Channel-to-Channel) IB Input Bias Current VCM = V+ 3 14 nA VCM = V– – 14 – 6 nA ∆IB Input Bias Current Shift VCM = V – to V+ 9 28 nA IOS Input Offset Current VCM = V + 0.6 3.6 nA VCM = V– 0.4 3.6 nA ∆IOS Input Offset Current Shift VCM = V – to V + 0.9 5.1 nA Input Bias Current Match VCM = V+ (Note 4) 0.6 5.1 nA (Channel-to-Channel) VCM = V – (Note 4) 0.6 5.1 nA AVOL Large-Signal Voltage Gain VO = ±4.25V, RL = 10k 250 450 V/mV Channel Separation VO = ±4.25V, RL = 10k 120 130 dB SR Slew Rate AV = – 1, RL = ∞ 0.018 0.04 V/µs CMRR Common Mode Rejection Ratio VCM = V– to V + 88 102 dB CMRR Match (Channel-to-Channel) VCM = V– to V + (Note 4) 82 99 dB VOL Output Voltage Swing LOW No Load V – + 0.032 V – + 0.060 V ISINK = 0.5mA V – + 0.135 V – + 0.270 V ISINK = 2.5mA V – + 0.235 V – + 0.470 V VOH Output Voltage Swing HIGH No Load V+ – 0.052 V+ – 0.026 V ISOURCE = 0.5mA V+ – 0.270 V+ – 0.135 V ISOURCE = 2.5mA V+ – 0.570 V+ – 0.265 V ISC Short-Circuit Current 10 18 mA IS Supply Current per Amplifier 70 80 µA GBW Gain Bandwidth Product f = 1kHz 120 kHz
0
C
TA
70
C, VS =
VOS Input Offset Voltage VCM = V+ ● 150 660 µV VCM = V– ● 150 660 µV ∆VOS Input Offset Voltage Shift VCM = V– to V + ● 90 500 µV Input Offset Voltage Match VCM = V–, V + (Notes 3, 4) ● 180 900 µV (Channel-to-Channel) IB Input Bias Current VCM = V+ ● 8 16 nA VCM = V– ● – 16 – 8 nA ∆IB Input Bias Current Shift VCM = V– to V+ ● 16 32 nA IOS Input Offset Current VCM = V + ● 0.8 5.3 nA VCM = V– ● 0.6 5.3 nA ∆IOS Input Offset Current Shift VCM = V – to V + ● 0.9 7.5 nA Input Bias Current Match VCM = V + (Note 4) ● 0.7 7.5 nA (Channel-to-Channel) VCM = V – (Note 4) ● 0.6 7.5 nA AVOL Large-Signal Voltage Gain VO = ±4.25V, RL = 10k ● 100 250 V/mV Channel Separation VO = ±4.25V, RL = 10k ● 120 130 dB CMRR Common Mode Rejection Ratio VCM = V– to V + ● 86 101 dB CMRR Match (Channel-to-Channel) VCM = V– to V + (Note 4) ● 80 98 dB 4
