Datasheet LTC6258, LTC6259, LTC6260 (Analog Devices) - 3
Description1.3MHz, 20µA Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page28 / 3 — ORDER INFORMATION http://www.linear.com/product/LTC6258#orderinfo. …
ORDER INFORMATION http://www.linear.com/product/LTC6258#orderinfo. SPECIFIED. TAPE AND REEL (MINI). TAPE AND REEL
ORDER INFORMATION http://www.linear.com/product/LTC6258#orderinfo SPECIFIED TAPE AND REEL (MINI) TAPE AND REEL
LTC6258/LTC6259/LTC6260
ORDER INFORMATION http://www.linear.com/product/LTC6258#orderinfo SPECIFIED TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6258IS6#TRMPBF LTC6258IS6#TRPBF LTGWD 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6258HS6#TRMPBF LTC6258HS6#TRPBF LTGWD 6-Lead Plastic TSOT-23 –40°C to 125°C LTC6258IDC#TRMPBF LTC6258IDC#TRPBF LGZS 6-Lead Plastic DFN (2mm × 2mm × 0.8mm) –40°C to 85°C LTC6258HDC#TRMPBF LTC6258HDC#TRPBF LGZS 6-Lead Plastic DFN (2mm × 2mm × 0.8mm) –40°C to 125°C LTC6259ITS8#TRMPBF LTC6259ITS8#TRPBF LTGWX 8-Lead Plastic TSOT-23 –40°C to 85°C LTC6259HTS8#TRMPBF LTC6259HTS8#TRPBF LTGWX 8-Lead Plastic TSOT-23 –40°C to 125°C LTC6259IDC#TRMPBF LTC6259IDC#TRPBF LGWT 8-Lead (2mm × 2mm × 0.8mm) Plastic DFN –40°C to 85°C LTC6259HDC#TRMPBF LTC6259HDC#TRPBF LGWT 8-Lead (2mm × 2mm × 0.8mm) Plastic DFN –40°C to 125°C
TUBE
LTC6259IMS8#PBF LTC6259IMS8#TRPBF LTGWW 8-Lead Plastic MSOP –40°C to 85°C LTC6259HMS8#PBF LTC6259HMS8#TRPBF LTGWW 8-Lead Plastic MSOP –40°C to 125°C LTC6259IMS#PBF LTC6259IMS8#TRPBF LTGWY 10-Lead Plastic MSOP –40°C to 85°C LTC6259HMS#PBF LTC6259HMS8#TRPBF LTGWY 10-Lead Plastic MSOP –40°C to 125°C LTC6260IMS#PBF LTC6260IMS#TRPBF 6260 16-Lead Plastic MSOP –40°C to 85°C LTC6260HMS#PBF LTC6260HMS#TRPBF 6260 16-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Parts ending with PBF are RoHS and WEEE Compliant. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/.
5V ELECTRICAL CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VSUPPLY = 5V, VCM = VOUT = VSUPPLY/2, CL = 10pF, VSHDN is unconnected. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V– + 0.3V –400 100 400 µV l –1000 1000 µV VCM = V+ – 0.3V –400 100 400 µV l –1000 1000 µV ∆VOS/∆T Input Offset Voltage Drift VCM = V– + 0.3V, V+ – 0.3V 1.5 µV/°C IB Input Bias Current (Note 7) VCM = V– + 0.3V l –75 –5 75 nA VCM = V+ – 0.3V l –75 0 75 nA IOS Input Offset Current VCM = V– + 0.3V l –75 –1 75 nA VCM = V+ – 0.3V l –75 –1 75 nA en Input Voltage Noise Density f = 1kHz 38 nV/√Hz Input Noise Voltage f = 0.1Hz to 10Hz 2 µVP-P in Input Current Noise Density f = 1kHz, VCM = 0V to 4V 500 fA/√Hz f = 1kHz, VCM = 4V to 5V 500 fA/√Hz RIN Input Resistance Differential 1 MΩ Common Mode 10 MΩ 6258960fa For more information www.linear.com/LTC6258 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information 5V Electrical Characteristics 1.8V Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Operation Applications Information Typical Application Related Parts
