Datasheet LTC3613 (Analog Devices) - 4
Description24V, 15A Monolithic Step Down Regulator with Differential Output Sensing
Pages / Page36 / 4 — The. ELECTRICAL CHARACTERISTICS. denotes the specifications which apply …
File Format / SizePDF / 464 Kb
The. ELECTRICAL CHARACTERISTICS. denotes the specifications which apply over the specified operating
The ELECTRICAL CHARACTERISTICS denotes the specifications which apply over the specified operating
LTC3613
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at T + A = 25°C. SVIN = 15V, VFB = VOSNS – VOSNS , unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator and Clock Synchronization
fOSC Free Running Switching Frequency RT = 205k 175 200 225 kHz RT = 80.6k 450 500 550 kHz RT = 38.8k 900 1000 1100 kHz CLKIH Clock Input High Level Into Mode/PLLIN 2 V CLKIL Clock Input Low Level Into Mode/PLLIN 0.5 V
Internal VCC Regulator and External VCC
INTVCC Internal VCC Voltage 6V < VIN < 24V 5.1 5.3 5.55 V INTVCC(%) Internal VCC Load Regulation ICC = 0mA to 50mA –1 –2 % EXTVCC(TH) EXTVCC Switchover Voltage EXTVCC Rising 4.4 4.6 4.75 V EXTVCC(HYS) EXTVCC Switchover Hysteresis 200 mV ΔINTVCC EXTVCC Voltage Drop VEXTVCC = 5V. ICC = 50mA 200 mV
PGOOD Output
PGDOV PGOOD Upper Threshold VFB Rising (With Respect to Regulated 5 7.5 10 % Feedback Voltage VREG) PGDUV PGOOD Lower Threshold VFB Falling (With Respect to Regulated –10 –7.5 –5 % Feedback Voltage VREG) PGDHYS PGOOD Hysteresis VFB Returning 2 % VPGD(LO) PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V tPGD(FALL) Delay from OV/UV Fault to PGOOD Falling (Note 5) 20 μs tPGD(RISE) Delay from OV/UV Recovery to PGOOD Rising (Note 5) 10 μs
RDS(ON)
RDS(ON) Top Switch On-Resistance 7.5 mohm Bottom Switch On-Resistance 5.5 mohm
Note 1:
Note 4:
The LTC3613 is tested under pulsed load conditions such that cause permanent damage to the device. Exposure to any Absolute TJ ≈ TA. The LTC3613E is guaranteed to meet specifications from Maximum Rating condition for extended periods may affect device 0°C to 125°C junction temperature. Specifications over the –40°C to reliability and lifetime. 125°C operating junction temperature range are assured by design,
Note 2:
T characterization and correlation with statistical process controls. The J is calculated from the ambient temperature, TA, and power dissipation, P LTC3613I is guaranteed over the full –40°C to 125°C operating junction D, as follows: T temperature range. Note that the maximum ambient temperature J = TA + (PD • 29°C/W) (θJA is simulated per JESD51-7 high effective thermal conductivity test board) consistent with these specifications is determined by specific operating conditions in conjunction with board layout, the rated package thermal θJC =1°C/W (θJC is simulated when heat sink is applied at the bottom impedance and other environmental factors. of the package.)
Note 5:
Delay times are measured using 50% levels.
Note 3:
The LTC3613 is tested in a feedback loop that adjusts V + FB = VOSNS – V – OSNS to achieve a specified error amplifier output voltage (ITH). 3613fa 4
