Datasheet LT1175 (Analog Devices) - 4
Description500mA Negative Low Dropout Micropower Regulator
Pages / Page20 / 4 — ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. …
File Format / SizePDF / 221 Kb
ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. TEMPERATURE RANGE
LT1175
LT1175IT LT1175IT#TR LT1175IT 5-Lead Plastic TO-220 –40°C to 125°C LT1175IT-5 LT1175IT-5#TR LT1175IT-5 5-Lead Plastic TO-220 –40°C to 125°C LT1175MPS8 LT1175MPS8#TR 1175MP 8-Lead Plastic SO –55°C to 125°C LT1175MPS8-5 LT1175MPS8-5#TR 175MP5 8-Lead Plastic SO –55°C to 125°C LT1175MPQ LT1175MPQ#TR LT1175MPQ 5-Lead Plastic DD-Pak –55°C to 125°C LT1175MPQ-5 LT1175MPQ-5#TR LT1175MPQ-5 5-Lead Plastic DD-Pak –55°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VOUT = 5V, VIN = 7V, IOUT = 0, VSHDN = 3V, ILIM2 and ILIM4 tied to VIN. To avoid confusion with “min” and “max” as applied to negative voltages, all voltages are shown as absolute values except where polarity is not obvious. PARAMETER CONDITIONS MIN TYP MAX UNITS
Feedback Sense Voltage Adjustable Part 3.743 3.8 3.857 V Fixed 5V Part 4.93 5.0 5.075 V Output Voltage Initial Accuracy Adjustable, Measured at 3.8V Sense 0.5 1.5 % Fixed 5V 0.5 1.5 % Output Voltage Accuracy (All Conditions) VIN – VOUT = 1V to VIN = 20V, IOUT = 0A to 500mA l 1.5 2.5 % P = 0 to PMAX, TJ = TMIN to TMAX (Note 4) Quiescent Input Supply Current VIN – VOUT ≤ 12V 45 65 μA l 80 μA GND Pin Current Increase with Load (Note 5) l 10 20 μA/mA Input Supply Current in Shutdown VSHDN = 0V 10 20 μA l 25 μA Shutdown Thresholds (Note 10) Either Polarity On SHDN Pin (C-, I-Grades) l 0.8 2.5 V Either Polarity On SHDN Pin (MP-Grade) l 0.8 2.6 V SHDN Pin Current (Note 3) VSHDN = 0V to 10V (Flows Into Pin) l 4 8 μA VSHDN = –15V to 0V (Flows Into Pin) 1 4 μA Output Bleed Current in Shutdown (Note 7) VOUT = 0V, VIN = 15V 0.1 1 μA l 1 5 μA SENSE Pin Input Current (Adjustable Part Only, Current Flows Out of Pin) l 75 150 nA (Fixed Voltage Only, Current Flows Out of Pin) l 12 20 μA Dropout Voltage (Note 8) IOUT = 25mA l 0.1 0.2 V IOUT = 100mA l 0.18 0.26 V IOUT = 500mA l 0.5 0.7 V ILIM2 Open, IOUT = 300mA l 0.33 0.5 V ILIM4 Open, IOUT = 200mA l 0.3 0.45 V ILIM2, ILIM4 Open, IOUT = 100mA l 0.26 0.45 V 1175ff 4
