Datasheet AD810-EP (Analog Devices)
Description | Low Power Video Op Amp with Disable |
Pages / Page | 8 / 1 — Low Power Video Op Amp with Disable. Enhanced Product. AD810-EP. … |
File Format / Size | PDF / 163 Kb |
Low Power Video Op Amp with Disable. Enhanced Product. AD810-EP. FEATURES. CONNECTION DIAGRAM. High speed
Low Power Video Op Amp with Disable Enhanced Product AD810-EP FEATURES CONNECTION DIAGRAM High speed AD810-EP 80 MHz typical −3 dB bandwidth (G = +1) OFFSET NULL 1 8 DISABLE 1000 V/µs typical slew rate –IN 2 7 +VS +IN 3 6 OUTPUT Ideal for video applications
001
–VS 4 5 OFSET NULL 30 MHz typical 0.1 dB bandwidth (G = +2, V
20396-
S = ±15 V)
Figure 1.
0.02% typical differential gain (VS = ±15 V) 0.04° typical differential phase (VS = ±15 V) Low noise 2.9 nV/√Hz typical input voltage noise 13 pA/√Hz typical inverting input current noise Low power 8.0 mA maximum supply current (quiescent) 2.1 mA typical supply current (power-down mode) High performance disable function Turn off time: 100 ns typical Break before make guaranteed Input to output isolation of 64 dB (off state) Specified for ±5 V and ±15 V operation ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) Military temperature range (−55°C to +125°C) Controlled manufacturing baseline 1 assembly/test site 1 fabrication site Product change notification Qualification data available on request APPLICATIONS Multimedia systems ADC or DAC buffers Avionics Missiles and munitions GENERAL DESCRIPTION
The AD810-EP is a composite and HDTV-compatible, current to only 2.1 mA, while the amplifier is not in use, to conserve feedback, video operational amplifier, ideal for use in systems power. Furthermore, the AD810-EP is specified over a power such as multimedia, digital tape recorders, and video cameras. supply range of ±5 V to ±15 V. The 0.1 dB flatness specification at a bandwidth of 30 MHz The AD810-EP works well as an ADC or DAC buffer in video (G = +2) and the differential gain and phase of 0.02% and 0.04° systems due to its unity gain (G = +1) −3 dB bandwidth of (NTSC) make the AD810-EP ideal for any broadcast quality 80 MHz. Because the AD810-EP is a transimpedance amplifier, video system. All these specifications are under load conditions this bandwidth can be maintained over a wide range of gains of 150 Ω (one 75 Ω back terminated cable). while featuring a low noise of 2.9 nV/√Hz for wide dynamic The AD810-EP is ideal for power sensitive applications such as range applications. video cameras, offering a low power supply current of 8.0 mA Additional application and technical information can be found maximum. The disable feature reduces the power supply current in the AD810 data sheet.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
