Datasheet TSSP940 (Vishay)
ManufacturerVishay
DescriptionIR Sensor Module for Reflective Sensor, Light Barrier, and Fast Proximity Applications
Pages / Page6 / 1 — TSSP940.. IR Sensor Module for Reflective Sensor, Light Barrier,. and …
File Format / SizePDF / 160 Kb
TSSP940.. IR Sensor Module for Reflective Sensor, Light Barrier,. and Fast Proximity Applications. FEATURES
Datasheet TSSP940 Vishay
TSSP940..
IR Sensor Module for Reflective Sensor, Light Barrier, and Fast Proximity Applications FEATURES
• Up to 2 m for presence and proximity sensing • Uses continuous AC signal or burst pattern of infrared light • Small sensitivity scattering range • PIN diode and sensor IC in one package • Low supply current • Shielding against EMI 1 • Visible light is suppressed by IR filter 2 • Insensitive to supply voltage ripple and noise 3 16672 • Supply voltage: 2.0 V to 3.6 V
DESIGN SUPPORT TOOLS AVAILABLE
• Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
D 3 3 D
3D Models
DESCRIPTION MECHANICAL DATA
The TSSP940.. series are the latest generation of compact infrared detector modules for presence, proximity, or light
Pinning:
curtain applications. They provide an active low output in 1 = OUT, 2 = GND, 3 = V response to infrared bursts at 940 nm. The frequency of the S burst should correspond to the carrier frequency shown in
the parts table. This component has not been qualified according to • Reflective sensors for hand dryers, towel or soap automotive specifications. dispensers, water faucets, toilet flush • Vending machine fall detection • Security and pet gates • Person or object vicinity switch • Fast proximity sensors for toys, robotics, drones, and other consumer and industrial uses
PARTS TABLE
38 kHz TSSP94038
Carrier frequency
56 kHz TSSP94056
Package
Mold
Pinning
1 = OUT, 2 = GND, 3 = VS
Dimensions (mm)
6.0 W x 6.95 H x 5.6 D
Mounting
Leaded
Application
Presence sensors, fast proximity sensors
BLOCK DIAGRAM PRESENCE SENSING
16833_8 +3 V 3 IR emitter VS 33 kΩ Envelope 1 signal OUT Band Demo- 38 kHz Input AMP pass dulator +3 V 2 Out to PIN GND μC Rev. 1.2, 17-Apr-2019
1
Document Number: 82843 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
