Datasheet J174, J175, J176, J177 (Philips) - 5
ManufacturerPhilips
DescriptionP-channel silicon field-effect transistors
Pages / Page6 / 5 — PACKAGE OUTLINE. Plastic single-ended leaded (through hole) package; 3 …
File Format / SizePDF / 32 Kb
PACKAGE OUTLINE. Plastic single-ended leaded (through hole) package; 3 leads. SOT54
PACKAGE OUTLINE Plastic single-ended leaded (through hole) package; 3 leads SOT54
Philips Semiconductors Product specification J174; J175; P-channel silicon field-effect transistors J176; J177
c E d A L b
1
e1
2
D e
3
b1 L1 0 2.5 5 mm scale
DIMENSIONS (mm are the original dimensions) UNIT A b b c D d E e e L (1) 1 1 L1
5.2 0.48 0.66 0.45 4.8 1.7 4.2 14.5 mm 2.54 1.27 2.5 5.0 0.40 0.56 0.40 4.4 1.4 3.6 12.7
Note
1. Terminal dimensions within this zone are uncontrolled to allow for flow of plastic and terminal irregularities.
REFERENCES OUTLINE EUROPEAN ISSUE DATE VERSION PROJECTION IEC JEDEC EIAJ
SOT54 TO-92 SC-43 97-02-28 April 1995 5 Document Outline DESCRIPTION PINNING QUICK REFERENCE DATA RATINGS THERMAL RESISTANCE STATIC CHARACTERISTICS DYNAMIC CHARACTERISTICS PACKAGE OUTLINE SOT54 DEFINITIONS
