Datasheet ADA4522-2-KGD (Analog Devices) - 8
Description55 V, EMI Enhanced, Zero Drift, Ultralow Noise, Rail-to-Rail Output Operational Amplifier
Pages / Page10 / 8 — ADA4522-2-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 4. …
File Format / SizePDF / 240 Kb
ADA4522-2-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
ADA4522-2-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
ADA4522-2-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage 60 V stress rating only; functional operation of the product at these Input Voltage Range (V−) − 300 mV to or any other conditions above those indicated in the operational (V+) + 300 mV section of this specification is not implied. Operation beyond Input Current1 ±10 mA the maximum operating conditions for extended periods may Differential Input Voltage ±5 V affect product reliability. Output Short-Circuit Duration to Ground Indefinite Temperature Range Storage −65°C to +150°C
ESD CAUTION
Operating −40°C to +125°C Junction −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C 1 The input pins have clamp diodes connected to the power supply pins. Limit the input current to 10 mA or less whenever input signals exceed the power supply rail by 0.3 V. Rev. 0 | Page 8 of 10 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5.0 V OPERATION ELECTRICAL CHARACTERISTICS—30 V OPERATION ELECTRICAL CHARACTERISTICS—55 V OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
