Datasheet ADA4528-1, ADA4528-2 (Analog Devices) - 5
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page24 / 5 — Data Sheet. ADA4528-1/ADA4528-2. Parameter. Symbol. Test …
RevisionF
File Format / SizePDF / 701 Kb
Data Sheet. ADA4528-1/ADA4528-2. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADA4528-1/ADA4528-2 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 2.2 V to 5.5 V 130 150 dB −40°C ≤ TA ≤ +125°C 127 dB Supply Current per Amplifier ISY IO = 0 mA 1.5 1.8 mA −40°C ≤ TA ≤ +125°C 2.2 mA DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ, CL = 100 pF, AV = +1 0.5 V/μs Settling Time to 0.1% tS VIN = 4 V step, RL = 10 kΩ, CL = 100 pF, AV = −1 10 µs Unity-Gain Crossover UGC VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 4 MHz Phase Margin ΦM VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 57 Degrees Gain Bandwidth Product GBP VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +100 3.4 MHz −3 dB Closed-Loop Bandwidth f−3dB VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 6.5 MHz Overload Recovery Time RL = 10 kΩ, CL = 100 pF, AV = −10 50 μs NOISE PERFORMANCE Voltage Noise en p-p f = 0.1 Hz to 10 Hz, AV = +100 99 nV p-p Voltage Noise Density en f = 1 kHz, AV = +100 5.9 nV/√Hz f = 1 kHz, AV = +100, VCM = 4.5 V 5.3 nV/√Hz Current Noise in p-p f = 0.1 Hz to 10 Hz, AV = +100 10 pA p-p Current Noise Density in f = 1 kHz, AV = +100 0.5 pA/√Hz Rev. F | Page 5 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION INPUT PROTECTION RAIL-TO-RAIL INPUT AND OUTPUT NOISE CONSIDERATIONS 1/f Noise Source Resistance Voltage Noise Density with Different Gain Configurations Residual Voltage Ripple COMPARATOR OPERATION PRINTED CIRCUIT BOARD LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
