Datasheet ADA4528-1, ADA4528-2 (Analog Devices) - 8
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page24 / 8 — ADA4528-1/ADA4528-2. Data Sheet. OUT A 1. 8 V+. OUT A. –IN A 2. …
RevisionF
File Format / SizePDF / 701 Kb
ADA4528-1/ADA4528-2. Data Sheet. OUT A 1. 8 V+. OUT A. –IN A 2. ADA4528-2. 7 OUT B. –IN A. OUT B. TOP VIEW. +IN A 3. 6 –IN B. (Not to Scale). +IN A
ADA4528-1/ADA4528-2 Data Sheet OUT A 1 8 V+ OUT A –IN A 2 ADA4528-2 7 OUT B –IN A OUT B TOP VIEW +IN A 3 6 –IN B (Not to Scale) +IN A
ADA4528-1/ADA4528-2 Data Sheet OUT A 1 8 V+ OUT A 1 8 V+ –IN A 2 ADA4528-2 7 OUT B –IN A ADA4528-2 2 7 OUT B TOP VIEW +IN A 3 6 –IN B TOP VIEW (Not to Scale) +IN A 3 6 –IN B (Not to Scale)
3 10
V– 4 5 +IN B
7-
V– 4 5 +IN B
43 09
NOTES
107
1. CONNECT THE EXPOSED PAD TO
437-
V– OR LEAVE IT UNCONNECTED.
09 Figure 6. ADA4528-2 Pin Configuration, 8-Lead MSOP Figure 7. ADA4528-2 Pin Configuration, 8-Lead LFCSP
Table 7. ADA4528-2 Pi n Function Descriptions Pin No. Mnemonic Description
1 OUT A Output, Channel A. 2 −IN A Inverting Input, Channel A. 3 +IN A Noninverting Input, Channel A. 4 V− Negative Supply Voltage. 5 +IN B Noninverting Input, Channel B. 6 −IN B Inverting Input, Channel B. 7 OUT B Output, Channel B. 8 V+ Positive Supply Voltage. EPAD Connect the exposed pad to V- or leave it unconnected. Rev. F | Page 8 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION INPUT PROTECTION RAIL-TO-RAIL INPUT AND OUTPUT NOISE CONSIDERATIONS 1/f Noise Source Resistance Voltage Noise Density with Different Gain Configurations Residual Voltage Ripple COMPARATOR OPERATION PRINTED CIRCUIT BOARD LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
