DatasheetsDatasheet ADA4505-1, ADA4505-2, ADA4505-4 …
Datasheet ADA4505-1, ADA4505-2, ADA4505-4 (Analog Devices)
Description | 10µA, RRIO, Zero Input Crossover Distortion Single Op Amp |
Pages / Page | 24 / 1 — 10 μA, Rail-to-Rail I/O, Zero Input. Crossover Distortion Amplifiers. … |
Revision | E |
File Format / Size | PDF / 870 Kb |
10 μA, Rail-to-Rail I/O, Zero Input. Crossover Distortion Amplifiers. Data Sheet. ADA4505-1. /ADA4505-2/. ADA4505-4. FEATURES
10 μA, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifiers Data Sheet ADA4505-1 /ADA4505-2/ ADA4505-4 FEATURES PIN CONFIGURATIONS PSRR: 100 dB minimum CMRR: 105 dB typical OUT 1 5 V+ ADA4505-1 OUT A 1 8 V+ Very low supply current: 10 μA per amplifier maximum V– 2 TOP VIEW –IN A 2 ADA4505-2 7 OUT B 1.8 V to 5 V single-supply or ±0.9 V to ±2.5 V dual-supply operation (Not to Scale) TOP VIEW +IN +IN A 3 6 –IN B 3 4 –IN
01
(Not to Scale) Rail-to-rail input and output
0 -004 6-
V– 4 5 +IN B
41 416
3 mV offset voltage maximum
07 07 Figure 1. 5-Lead SOT-23 (RJ-5) Figure 2. 8-Lead MSOP (RM-8)
Very low input bias current: 0.5 pA typical APPLICATIONS BALL A1 INDICATOR BALL A1 Pressure and position sensors CORNER Remote security OUT V+ A1 A2 Medical monitors OUT B V+ OUT A V– NC A1 A2 A3 Battery-powered consumer equipment B1 B2 Hazard detectors –IN B –IN A +IN –IN B1 B3 GENERAL DESCRIPTION C1 C2 +IN B V– +IN A
The ADA4505-1/ADA4505-2/ADA4505-4 are single, dual, and
C1 C2 C3 ADA4505-1
quad micropower amplifiers featuring rail-to-rail input and output
TOP VIEW
swings while operating from a single 1.8 V to 5 V power supply 8
(BALL SIDE DOWN)
3
ADA4505-2
-06
Not to Scale
-00
TOP VIEW
or from dual ±0.9 V to ±2.5 V power supplies. 416
NC = NO CONNECT
16
(BALL SIDE DOWN)
07 74 0 Employing a new circuit technology, these low cost amplifiers Figure 3. 6-Ball WLCSP (CB-6-7) Figure 4. 8-Ball WLCSP (CB-8-2) offer zero input crossover distortion (excellent PSRR and CMRR
BALL A1
performance) and very low bias current, while operating with a
INDICATOR
supply current of less than 10 μA per amplifier.
OUT D OUT A –IN A A1 A2 A3
This combination of features makes the ADA4505-x amplifiers
–IN D V– +IN A
ideal choices for battery-powered applications because they
B1 B2 B3
minimize errors due to power supply voltage variations over the
+IN D +IN B OUT A 1 14 OUT D
lifetime of the battery and maintain high CMRR even for a rail-
C1 C3 –IN A 2 13 –IN D
to-rail op amp.
+IN C V+ –IN B ADA4505-4 +IN A 3 12 +IN D D1 D2 D3
Remote battery-powered sensors, handheld instrumentation
TOP VIEW V+ 4 11 V– –IN C OUT C OUT B (Not to Scale)
and consumer equipment, hazard detectors (for example, smoke,
E1 E2 E3 +IN B 5 10 +IN C
fire, and gas), and patient monitors can benefit from the features
–IN B 6 9 –IN C ADA4505-4
of the ADA4505-x amplifiers. 05
TOP VIEW
61 0
OUT B 7 8 OUT C
0
(BALL SIDE DOWN)
6- 16-
Not to Scale
41 074 07 The ADA4505-x family is specified for both the industrial temperature range (−40°C to +85°C) and the extended industrial Figure 5. 14-Lead TSSOP (RU-14) Figure 6. 14-Ball WLCSP (CB-14-1) temperature range (−40°C to +125°C). The ADA4505-1 single amplifier is available in a tiny 5-lead SOT-23 and a 6-ball WLCSP. The ADA4505-2 dual amplifier is available in a standard 8-lead MSOP and a 8-ball WLCSP. The ADA4505-4 quad amplifier is available in a 14-lead TSSOP and a 14-ball WLCSP. The ADA4505-x family is a member of a growing series of zero crossover op amps offered by Analog Devices, Inc., including the AD8505/AD8506/AD8508, which also operate from a single 1.8 V to 5 V power supply or from dual ±0.9 V to ±2.5 V power supplies.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2008–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Pin Configurations Revision History Specifications Electrical Characteristics—1.8 V Operation Electrical Characteristics—5 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Applications Information Pulse Oximeter Current Source Four-Pole, Low-Pass Butterworth Filter for Glucose Monitor Outline Dimensions Ordering Guide
