Datasheet ADA4084-1, ADA4084-2, ADA4084-4 (Analog Devices) - 3
Description30 V, Low Noise, Rail-to-Rail Input/Output, Low Power Operational Single Amplifier
Pages / Page36 / 3 — Data Sheet. ADA4084-1/ADA4084-2/ADA4084-4. 11/2013—Rev. C to Rev. D. …
RevisionI
Data Sheet. ADA4084-1/ADA4084-2/ADA4084-4. 11/2013—Rev. C to Rev. D. 2/2012—Rev. 0 to Rev. A. 4/2013—Rev. B to Rev. C
Data Sheet ADA4084-1/ADA4084-2/ADA4084-4 11/2013—Rev C to Rev D 2/2012—Rev 0 to Rev A 4/2013—Rev B to Rev C
Data Sheet ADA4084-1/ADA4084-2/ADA4084-4 11/2013—Rev. C to Rev. D
Added Figure 55 and Figure 57 ... 17 Added 14-Lead TSSOP and 16-Lead LFCSP Packages ... Universal Added Startup Characteristics Section .. 23 Added ADA4084-4 ... Universal Moved Figure 78 .. 23 Change to Features Section and Applications Section ... 1 Changes to Output Phase Reversal Section and Comparator Added Figure 2 and Figure 3; Renumbered Sequentially .. 1 Operation Section ... 24 Changes to Table 2 .. 3 Updated Outline Dimensions .. 25 Changes to Table 3 .. 4 Changes to Ordering Guide ... 26 Changes to Table 4 .. 5 Changes to Table 5 and Table 6 ... 6
Changes to Typical Performance Characteristics Section ... 7 Changes to Data Sheet Title ... 1 Updated Outline Dimensions .. 27 Changes to Voltage Range in General Description .. 1 Changes to Ordering Guide ... 28 Changes to Supply Current/Amplifier Parameter, Table 2 .. 3 Changes to Common-Mode Rejection Ratio Parameter, Table 3 .. 4
Changes to Common-Mode Rejection Ratio Parameter, Table 4 .. 5 Changes to Figure 48 Caption ... 15 Changes to Figure 2 .. 6 Updated Outline Dimensions .. 25 Changes to Figure 24 .. 10 Changes to Figure 32 .. 12
6/2012—Rev. A to Rev. B
Changes to Figure 47 .. 14 Added LFCSP Package... Universal Changes to Figure 55 .. 16 Changes to Figure 1 ... 1 Changes to Figure 62 .. 17 Changes to Output Voltage High Parameter, Table 4 ... 5 Changes to Figure 73 .. 20 Added Figure 5 and Figure 7, Renumbered Sequentially .. 7 Added Figure 30 and Figure 32 ... 12
10/2011—Revision 0: Initial Version
Rev. I | Page 3 of 36 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION START-UP CHARACTERISTICS INPUT PROTECTION OUTPUT PHASE REVERSAL DESIGNING LOW NOISE CIRCUITS IN SINGLE-SUPPLY APPLICATIONS COMPARATOR OPERATION LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
