Datasheet ADA4665-2-KGD (Analog Devices)
Description16 V, 1.2 MHz, CMOS Rail-to-Rail Input/Output Operational Amplifier
Pages / Page8 / 1 — 16 V, 1.2 MHz, CMOS Rail-to-Rail. Input/Output Operational Amplifier. …
File Format / SizePDF / 211 Kb
16 V, 1.2 MHz, CMOS Rail-to-Rail. Input/Output Operational Amplifier. Known Good Die. ADA4665-2-KGD. FEATURES
Datasheet ADA4665-2-KGD Analog Devices
16 V, 1.2 MHz, CMOS Rail-to-Rail Input/Output Operational Amplifier Known Good Die ADA4665-2-KGD FEATURES GENERAL DESCRIPTION Low supply current per amplifier: 290 µA typical, IOUT = 0 mA
The ADA4665-2-KGD is a rail-to-rail, input and output, dual
Low input bias current: 1 pA maximum
amplifier optimized for lower power budget designs. The
Wide gain bandwidth product: 1.2 MHz typical
ADA4665-2-KGD offers a low supply current of 400 µA
Slew rate: 1 V/µs typical
maximum per amplifier at 25°C and 600 μA maximum per
Offset voltage drift: 3 µV/°C typical
amplifier over the extended industrial temperature range. This
Single-supply operation: 5 V to 16 V
feature makes the ADA4665-2-KGD wel suited for low power
Dual-supply operation: ±2.5 V to ±8 V
applications.
Unity-gain stable
In addition, the ADA4665-2-KGD has a low bias current of 1 pA maximum, low offset voltage drift of 3 µV/°C, and bandwidth of
1.2 MHz. The combination of these features, together with a
Portable systems
wide supply voltage range from 5 V to 16 V, allows the device to
High density power budget systems
be used in a wide variety of other applications, including
Medical equipment
process control, instrumentation equipment, buffering, and
Physiological measurement
sensor front ends.
Precision references Multipole filters
Furthermore, its rail-to-rail input and output swing adds to its
Sensors
versatility. The ADA4665-2-KGD is specified from −40°C to
Transimpedance amplifiers
+125°C.
Buffer and level shifting
Additional application and technical information can be found in the ADA4665-2 data sheet. Known Good Die (KGD): this die is ful y guaranteed to data sheet specifications.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—16 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTION OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
