Datasheet OP200 (Analog Devices) - 10
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page16 / 10 — OP200. Data Sheet. 100. TA = 25°C VS = ±15V. 0.7. 0.6. V = 1000. V/ (µ. N …
RevisionG
File Format / SizePDF / 363 Kb
OP200. Data Sheet. 100. TA = 25°C VS = ±15V. 0.7. 0.6. V = 1000. V/ (µ. N (. V = 100. 0.5. EC EJ. AV = 10. 0.4. -LOO. Y R. D E. PPL. AV = 1. 0.3. LOS. ER W. 0.2. –20
OP200 Data Sheet 100 TA = 25°C VS = ±15V 0.7 0.6 V = 1000 V/ (µ N ( V = 100 0.5 EC EJ AV = 10 0.4 -LOO Y R D E PPL AV = 1 0.3 LOS ER W 0.2 –20
OP200 Data Sheet 100 TA = 25°C VS = ±15V 0.7 80 A V) 0.6 B) V = 1000 d 60 V/ (µ N ( N AI A IO V = 100 0.5 T G 40 P EC EJ AV = 10 0.4 -LOO 20 Y R D E PPL AV = 1 0.3 LOS 0 SU C ER W 0.2 –20 PO
021 018
–40
00322-
0.1
00322-
–75 –50 –25 0 25 50 75 100 125 1 10 100 1k 10k 100k 1M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 18. Power Supply Rejection vs. Temperature Figure 21. Closed-Loop Gain vs. Frequency
6000 30 V T S = ±15V A = 25°C R V L = 2kΩ S = ±15V 5000 25 V p-p AT 1% V) DISTORTION m ) 4000 V 20 (V/ G ( IN A WIN 3000 15 P G T S O U O -L TP 2000 10 OU PEN O 1000 5
019 022
0
00322-
0
00322-
–75 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz)
Figure 19. Open-Loop Gain vs. Temperature Figure 22. Maximum Output Swing vs. Frequency
140 1 T A A = 25°C V = 100 VS = ±15V 120 ) % ( AV = 10 100 ) TION dB ( 0.1 80 rees) IN TOR A IS V = 1 Deg GA ( D 60 0 T IC F PHASE HI ON -LOOP S M N 40 90 E R E A 0.01 OP GAIN HAS L H 20 135 P TA = 25°C VS = ±15V TOTA 0 180 VOUT = 10V p-p
020 023
RL = 2kΩ –20
00322-
0.001
00322-
10 100 1k 10k 100k 1M 100 1k 10k FREQUENCY (Hz) FREQUENCY (Hz)
Figure 20. Open-Loop Gain and Phase Shift vs. Frequency Figure 23. Total Harmonic Distortion vs. Frequency Rev. G | Page 10 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
