Datasheet AD8362 (Analog Devices) - 10
Description50 Hz to 3.8 GHz 65d dB TruPwr Detector
Pages / Page33 / 10 — AD8362. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 4.5. 4.0. 3.0. …
RevisionF
AD8362. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 4.5. 4.0. 3.0. 100MHz. 3.6. 2.4. 3.5. 2200MHz. 3.2. 1.8. 2.8. 1.2. –40°C. (dB). 0.6. 2.5. T (V)
AD8362 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 4.5 4.0 3.0 100MHz 3.6 2.4 3.5 2200MHz 3.2 1.8 2.8 1.2 –40°C (dB) 0.6 2.5 T (V)
AD8362 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 4.5 4.0 3.0 4.0 100MHz 3.6 2.4 3.5 2200MHz 3.2 1.8 2.8 1.2 3.0 –40°C (dB) 2.4 0.6 2.5 UT T (V) O U T (V) U 2.0 0 N V VO 2.0 VO 1.6 –0.6 R I 1.5 2700MHz +25°C +85°C –1.2 RRO 1.2 –40°C E 1.0 +25°C 0.8 –1.8 +85°C 0.5 900MHz 0.4 –2.4 1900MHz 0 0 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15 –3.0
008
011
INPUT AMPLITUDE (dBm) INPUT AMPLITUDE (dBm)
02923- 02923- Figure 8. Output Voltage (VOUT) vs. Input Amplitude (dBm), Figure 11. VOUT and Law Conformance vs. Input Amplitude, Frequencies: 100 MHz, 900 MHz, 1900 MHz, 2200 MHz, and 2700 MHz; Frequency 1900 MHz, Sine Wave, Temperatures: −40°C, +25°C, and +85°C Sine Wave, Differential Drive
4.0 3.0 3.0 3.6 2.4 2.5 3.2 1.8 2.0 2.8 –40°C 1.2 1.5 2.4 (dB) 0.6 (dB) 1.0 100MHz UT O UT 0.5 T (V) 2.0 0 O U N V N V 0 VO 1.6 +25°C –0.6 R I R I –0.5 –1.2 RRO 2200MHz 1900MHz 1.2 E +85°C ERRO –1.0 –40°C 0.8 –1.8 –1.5 900MHz +85°C –2.0 0.4 +25°C –2.4 –2.5 0 2700MHz –3.0 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
012
–3.0–60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
009
02923-
02923- Figure 9. Logarithmic Law Conformance vs. Input Amplitude, Figure 12. VOUT and Law Conformance vs. Input Amplitude, Frequencies: 100 MHz, 900 MHz, 1900 MHz, 2200 MHz, and 2700 MHz; Frequency 2200 MHz, Sine Wave, Temperatures: −40°C, +25°C, and +85°C Sine Wave, Differential Drive
4.0 3.0 4.0 3.6 2.4 3.5 3.2 1.8 CW –40°C 3.0 2.8 1.2 2.4 (dB) 0.6 2.5 UT IS95 REVERSE LINK T (V) +25°C O U 2.0 0 T (V) N V U 2.0 W-CDMA 8-CHANNEL VO 1.6 +85°C –0.6 R I VO 1.5 W-CDMA 15-CHANNEL 1.2 –40°C RRO –1.2 E 1.0 0.8 –1.8 0.4 +85°C –2.4 0.5 +25°C 0 –3.0 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
010
013
02923-
02923- Figure 10. VOUT and Law Conformance vs. Input Amplitude, Figure 13. VOUT vs. Input Amplitude with Different Waveforms, CW, IS95 Frequency 900 MHz, Sine Wave, Temperatures: −40°C, +25°C, and +85°C Reverse Link, W-CDMA 8-Channel, W-CDMA 15-Channel, Frequency 900 MHz Rev. F | Page 10 of 33 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS CHARACTERIZATION SETUP EQUIPMENT ANALYSIS CIRCUIT DESCRIPTION SQUARE LAW DETECTION VOLTAGE vs. POWER CALIBRATION OFFSET ELIMINATION TIME-DOMAIN RESPONSE OF THE CLOSED LOOP OPERATION IN RF MEASUREMENT MODE BASIC CONNECTIONS DEVICE DISABLE RECOMMENDED INPUT COUPLING Choosing Input Coupling Capacitors Single-Ended Input Drive OPERATION AT LOW FREQUENCIES CHOOSING A VALUE FOR CHPF CHOOSING A VALUE FOR CLPF ADJUSTING VTGT TO ACCOMMODATE SIGNALS WITH VERY HIGH CREST FACTORS ALTERING THE SLOPE TEMPERATURE COMPENSATION AND REDUCTION OF TRANSFER FUNCTION RIPPLE TEMPERATURE COMPENSATION AT VARIOUS WiMAX FREQUENCIES UP TO 3.8 GHz OPERATION IN CONTROLLER MODE RMS VOLTMETER WITH 90 dB DYNAMIC RANGE AD8362 EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
