Datasheet ADA4817-1, ADA4817-2 (Analog Devices) - 3
DescriptionDual, Low Noise, 1 GHz FastFET Op Amplifier
Pages / Page31 / 3 — Data Sheet. ADA4817-1. /ADA4817-2. 5/2013—Rev. A to Rev. B. 3/2009—Rev. 0 …
RevisionG
File Format / SizePDF / 632 Kb
Data Sheet. ADA4817-1. /ADA4817-2. 5/2013—Rev. A to Rev. B. 3/2009—Rev. 0 to Rev. A. 11/2008—Revision 0: Initial Version
Data Sheet ADA4817-1 /ADA4817-2 5/2013—Rev A to Rev B 3/2009—Rev 0 to Rev A 11/2008—Revision 0: Initial Version
Data Sheet ADA4817-1 /ADA4817-2 5/2013—Rev. A to Rev. B
Changes to Figure 21, Figure 22, and Figure 24 .. 10 Changes to Figure 3... 1 Changes to Figure 33 .. 12 Changes to Figure 7... 7 Added Figure 34; Renumbered Sequential y ... 12 Updated Outline Dimensions .. 24 Changes to Thermal Considerations Section and Power-Down Changes to Ordering Guide ... 25 Operation Section ... 15
Changes to Capacitive Feedback Section and Figure 46 .. 16 Added Higher Frequency Attenuation Section, Figure 47, Added 8-Lead SOIC Package .. Universal Figure 48, and Figure 49; Renumbered Sequential y ... 16 Changes to Features Section and General Description Section .. 1 Updated Outline Dimensions.. 24 Changes to Table 1... 3 Changes to Ordering Guide ... 25 Changes to Table 2... 4 Changes to Figure 4... 5
Changes to Figure 9, Figure 11, and Figure 12 .. 8 Rev. G | Page 3 of 31 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ±5 V OPERATION 5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM SAFE POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION CLOSED-LOOP FREQUENCY RESPONSE NONINVERTING CLOSED-LOOP FREQUENCY RESPONSE INVERTING CLOSED-LOOP FREQUENCY RESPONSE WIDEBAND OPERATION DRIVING CAPACITIVE LOADS THERMAL CONSIDERATIONS POWER-DOWN OPERATION CAPACITIVE FEEDBACK HIGHER FREQUENCY ATTENUATION LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS SIGNAL ROUTING POWER SUPPLY BYPASSING GROUNDING EXPOSED PAD LEAKAGE CURRENTS INPUT CAPACITANCE INPUT-TO-INPUT/OUTPUT COUPLING APPLICATIONS INFORMATION LOW DISTORTION PINOUT WIDEBAND PHOTODIODE PREAMP HIGH SPEED JFET INPUT INSTRUMENTATION AMPLIFIER ACTIVE LOW-PASS FILTER (LPF) OUTLINE DIMENSIONS ORDERING GUIDE
