Datasheet OP470S (Analog Devices)
DescriptionVery Low-Noise Quad Operational Amplifier
Pages / Page5 / 1 — This. specification. documents. the. detailed. requirements. for. Analog. …
File Format / SizePDF / 478 Kb
This. specification. documents. the. detailed. requirements. for. Analog. Devices. space. qualified. die. including. die. qualification. as. described
Datasheet OP470S Analog Devices
This specification documents the detailed requirements for Analog Devices space qualified die including die qualification as described for Class K in MIL-PRF-38534, Appendix C, Table C-II except as modified herein. The manufacturing flow described in the STANDARD DIE PRODUCTS PROGRAM brochure at http://www.analog.com/marketSolutions/militaryAerospace/pdf/Die_Broc.pdf is to be considered a part of this specification. This data sheet specifically details the space grade version of this product. A more detailed operational description and a complete data sheet for commercial product grades can be found at www.analog.com/OP470
. The complete part number(s) of this specification follow: Part Number Description OP470-000C Very Low-Noise Quad Operational Amplifier OP470R000C Radiation Tested Very Low-Noise Quad Operational Amplifier
