Datasheet HMC8205BCHIPS (Analog Devices)
Description0.4 GHz to 6 GHz, 35 W, GaN, Power Amplifier
Pages / Page19 / 1 — 0.4 GHz to 6 GHz, 35 W, GaN,. Power Amplifier. Data Sheet. HMC8205BCHIPS. …
RevisionA
File Format / SizePDF / 318 Kb
0.4 GHz to 6 GHz, 35 W, GaN,. Power Amplifier. Data Sheet. HMC8205BCHIPS. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC8205BCHIPS Analog Devices, Revision: A
0.4 GHz to 6 GHz, 35 W, GaN, Power Amplifier Data Sheet HMC8205BCHIPS FEATURES FUNCTIONAL BLOCK DIAGRAM High output power: 45.5 dBm typical at PIN = 24 dBm High power gain: 22 dB typical at P 2 IN = 24 dBm VDD2 High PAE: 40% typical at PIN = 28 dBm Die size: 4.8 mm × 3.4 mm × 0.1 mm 3 RFOUT APPLICATIONS Military jammers V Commercial and military radar GG1 4 Power amplifier stage for wireless infrastructure 1 RFIN Test and measurement equipment VDD1 5
001 13790- Figure 1.
GENERAL DESCRIPTION
The HMC8205BCHIPS is a gallium nitride (GaN), broadband amplifier. In addition, dc blocking capacitors for the RFIN and power amplifier that delivers 45.5 dBm (35 W) with 40% power RFOUT pins are integrated into the HMC8205BCHIPS. added efficiency (PAE) across an instantaneous bandwidth of The HMC8205BCHIPS is ideal for pulsed or continuous wave 0.4 GHz to 6 GHz. No external matching is required to achieve (CW) applications, such as military jammers, wireless ful band operation. No external inductor is required to bias the infrastructure, radar, and general-purpose amplification.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2018–2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTION INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
