Datasheet HMC8205BF10 (Analog Devices)
Description0.3 GHz to 6 GHz, 35 W, GaN Power Amplifier
Pages / Page14 / 1 — 0.3 GHz to 6 GHz, 35 W, GaN. Power Amplifier. Data Sheet. HMC8205BF10. …
RevisionC
File Format / SizePDF / 262 Kb
0.3 GHz to 6 GHz, 35 W, GaN. Power Amplifier. Data Sheet. HMC8205BF10. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC8205BF10 Analog Devices, Revision: C
0.3 GHz to 6 GHz, 35 W, GaN Power Amplifier Data Sheet HMC8205BF10 FEATURES FUNCTIONAL BLOCK DIAGRAM High PSAT: 46 dBm High power gain: 20 dB High PAE: 38% Instantaneous bandwidth: 0.3 GHz to 6 GHz 1 HMC8205BF10 10 Supply voltage: VDD = 50 V at 1300 mA VDD2 NC 10-lead LDCC package VDD2 NC 2 9 APPLICATIONS 3 8 Military jammers RFIN RFOUT Commercial and military radar 4 7 Power amplifier stage for wireless infrastructure NC VGG1 Test and measurement equipment NC VDD1 5 6 PACKAGE BASE GND
001 13790- Figure 1.
GENERAL DESCRIPTION
The HMC8205BF10 is a gallium nitride (GaN) broadband The HMC8205BF10 is ideal for pulsed or continuous wave power amplifier delivering 45.5 dBm (35 W) with 38% power (CW) applications, such as military jammers, wireless added efficiency (PAE) across an instantaneous bandwidth of infrastructure, radar, and general-purpose amplification. 0.3 GHz to 6 GHz. No external matching is required to achieve The HMC8205BF10 amplifier is a 10-lead ceramic leaded chip ful band operation. Additionally, no external inductor is carrier (LDCC). required to bias the amplifier. Also, dc blocking capacitors for the RFIN and RFOUT pins are integrated into the HMC8205BF10.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017–2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Application Circuit Evaluation PCB Outline Dimensions Ordering Guide
