Datasheet ADL5506 (Analog Devices)
Description30 MHz to 4.5 GHz, 45 dB RF Detector
Pages / Page23 / 1 — 30 MHz to 4.5 GHz, 45 dB. RF Detector. Data Sheet. ADL5506. FEATURES. …
RevisionC
30 MHz to 4.5 GHz, 45 dB. RF Detector. Data Sheet. ADL5506. FEATURES. GENERAL DESCRIPTION. Complete RF detector function
Datasheet ADL5506 Analog Devices, Revision: C
30 MHz to 4.5 GHz, 45 dB RF Detector Data Sheet ADL5506 FEATURES GENERAL DESCRIPTION Complete RF detector function
The ADL5506 is a complete, low cost subsystem for the
Typical dynamic range: 45 dB
measurement of RF signals in the 30 MHz to 4.5 GHz frequency
Frequency range from 30 MHz to 4.5 GHz
range, with a typical dynamic range of 45 dB, intended for use
Excellent temperature stability
in a wide variety of wireless terminal devices. It provides a wider
Stable linear in decibel response
dynamic range and better accuracy than is possible using
Power on/off response time: 65 ns/145 ns (rise/fall)
discrete diode detectors. In particular, its temperature stability
−5 dBm input power applied
is excellent over −40°C to +85°C.
Operates from −40°C to +85°C
Its high sensitivity al ows measurement of low power levels, thus
Low power: 3.8 mA at 3.0 V
reducing the amount of power that needs to be coupled to the
Power supply voltage range from 2.5 V to 5.5 V
detector. It is essentially a voltage responding device, with a
Disable current <1 µA
typical dynamic range of 45 dB.
AEC-Q100 qualified for automotive applications
For convenience, the signal is internally ac-coupled, using a
5 pF capacitor and a broadband 50 Ω match, with an external
RSSI and TSSI for wireless terminal devices
shunt resistor of 52 Ω. This high-pass coupling, with a corner at
RF transmitter or receiver power measurement
approximately 19 MHz, determines the lowest operating
Automotive RF bidirectional amplifiers
frequency. Therefore, the source can be dc grounded. The ADL5506 output increases from approximately 0.14 V to a little over 1 V as the input signal level increases from 1.25 mV rms (−45 dBm) to 224 mV rms (0 dBm). The output is proportional to the logarithm of the input power level; that is, the reading is presented directly in decibels and is scaled about 18 mV/dB at 900 MHz. A capacitor can be connected between the VLOG pin and the CFLT pin when it is desirable to increase the time interval over which averaging of the input waveform occurs. The ADL5506 is available in a 6-ball WLCSP and consumes 3.8 mA from a 3.0 V supply. When powered down, the typical disable supply current is <1 µA.
FUNCTIONAL BLOCK DIAGRAM CFLT V-I + I-V VLOG DET DET DET DET DET RFIN BAND-GAP VPOS 10dB 10dB 10dB 10dB REFERENCE ENBL OFFSET COMPENSATION ADL5506
001
COMM
1768- 1 Figure 1.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT LOG CONFORMANCE ERROR CALCULATION Filter Capacitor Input Coupling Options Effect of Waveform Type on Intercept Temperature Drift at High Frequencies Operation Above 4.5 GHz VLOG Output Noise VLOG Pulse Response Time Device Handling EVALUATION BOARD LAND PATTERN AND SOLDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
