Datasheet AD8315 (Analog Devices) - 4
Description50 dB GSM PA Controller
Pages / Page22 / 4 — AD8315. Data Sheet. Parameter Test. Conditions/Comments. Min. Typ. Max. …
RevisionD
File Format / SizePDF / 450 Kb
AD8315. Data Sheet. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
AD8315 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4 link to page 8
POWER INTERFACE Pin VPOS Supply Voltage 2.7 5.5 V Quiescent Current ENBL high 8.5 10.7 mA Over Temperature −30°C ≤ TA ≤ +85°C 12.9 mA Disable Current6 ENBL low 4 10 μA Over Temperature −30°C ≤ TA ≤ +85°C 13 μA 1 Operation down to 0.02 GHz is possible. 2 Mean and standard deviation specifications are available in Table 2 3 See Figure 12 for plot of input impedance vs. frequency. 4 This parameter is guaranteed but not tested in production. Limit is −3 sigma from the mean. 5 Response time in a closed-loop system depends on the filter capacitor (CFLT) used and the response of the variable gain element. 6 This parameter is guaranteed but not tested in production. Maximum specified limit on this parameter is the 6 sigma value.
Table 2. Typical Specifications at Selected Frequencies at 25°C (Mean and Sigma) ±1 dB Dynamic Range Slope (mV/dB) Intercept (dBV) Low Point (dBV) High Point (dBV) Frequency (GHz) Mean Sigma Mean Sigma Mean Sigma Mean Sigma
0.1 23.8 0.3 −70.1 1.8 −57.7 1.3 −10.6 0.8 0.9 23.2 0.4 −72.6 1.8 −61.0 1.3 −11.2 0.8 1.9 22.2 0.3 −73.8 1.6 −62.9 0.9 −18.5 1.7 2.5 22.3 0.4 −75.6 1.5 −64.0 1.1 −20.0 1.7 Rev. D | Page 4 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC THEORY CONTROLLER-MODE LOG AMPS CONTROL LOOP DYNAMICS Example PRACTICAL LOOP A NOTE ABOUT POWER EQUIVALENCY BASIC CONNECTIONS RANGE ON VSET AND RFIN TRANSIENT RESPONSE MOBILE HANDSET POWER CONTROL EXAMPLE ENABLE AND POWER-ON INPUT COUPLING OPTIONS USING THE CHIP SCALE PACKAGE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
