Datasheet MAX6033 (Maxim)
ManufacturerMaxim
DescriptionHigh-Precision, Low-Dropout SOT23 Series Voltage Reference
Pages / Page13 / 1 — EVALUATION KIT AVAILABLE. here. MAX6033. High-Precision, Low-Dropout. …
EVALUATION KIT AVAILABLE. here. MAX6033. High-Precision, Low-Dropout. SOT23 Series Voltage Reference. General Description
Datasheet MAX6033 Maxim
link to page 12 link to page 11
Click
here
for production status of specific part numbers.
MAX6033 High-Precision, Low-Dropout SOT23 Series Voltage Reference General Description Benefits and Features
The MAX6033 ultra-high-precision series voltage reference ● Stable Performance Over Temperature and Time features a low 7ppm/°C (max) temperature coefficient and Improves Accuracy a low dropout voltage (200mV, max). Low temperature • Ultra-Low Temperature Drift: 7ppm/°C (max) drift and low noise make the MAX6033 ideal for use with • ±0.04% Initial Accuracy high-resolution ADCs or DACs. • Stable with Capacitive Loads up to 100µF ● This device uses bandgap technology for low-noise • Low 16μVP-P Noise (0.1Hz to 10Hz) (2.5V Output) performance and excellent accuracy. Laser-trimmed, • Low 200mV Dropout Voltage high-stability, thin-film resistors, and post-package • Excellent Load Regulation: 0.001mV/mA trimming guarantee excellent initial accuracy ● Low 40μA Quiescent Current Reduces System (±0.04%, max). The MAX6033 consumes only 40µA Power Consumption of supply current and sources up to 15mA. Series ● 2.7V to 12.6V Supply Voltage Eases Power mode references save system power and use Requirements minimal external components compared to two- terminal shunt references.
Pin Configuration
● The MAX6033 is available in the miniature 6-pin SOT23 package and is offered over the automotive TOP VIEW temperature range (-40°C to +125°C). +
Applications
I.C.* 1 6 OUTS ● Precision Regulators
MAX6033
GND 2 5 OUTF ● A/D and D/A Converters ● Power Supplies ● Hard-Disk Drives I.C.* 3 4 IN ● High-Accuracy Industrial and Process Control
SOT23
● Hand-Held Instruments *I.C. = INTERNALLY CONNECTED: DO NOT USE
Typical Operating Circuit
appears at end of data sheet.
Ordering Information/Selector Guide PART OUTPUT TEMP COEFF INITIAL ACCURACY VOLTAGE (V) (PPM/°C) (%) TOP MARK
MAX6033AAUT25-T 2.500 10 0.04 ABDF MAX6033BAUT25+T 2.500 15 0.20 +AAXL MAX6033BAUT25-T 2.500 15 0.20 AAXL MAX6033CAUT25-T 2.500 40 0.10 AAXH MAX6033CAUT25+T 2.500 40 0.10 +AAXH
continued on last page. #Denotes a RoHS-compliant device that may include lead(Pb) that is exempt under the RoHS requirements. T = Tape and reel. *Denote as a future part. 19-2300; Rev 8; 8/21 Document Outline _GoBack
