Datasheet ADG5412F-EP (Analog Devices)
Description | Fault Protection and Detection, 10 Ω RON, Quad SPST Switches |
Pages / Page | 22 / 1 — Fault Protection and Detection,. 10 Ω R. ON, Quad SPST Switches. Enhanced … |
Revision | B |
File Format / Size | PDF / 603 Kb |
Fault Protection and Detection,. 10 Ω R. ON, Quad SPST Switches. Enhanced Product. ADG5412F-EP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Fault Protection and Detection, 10 Ω R ON, Quad SPST Switches Enhanced Product ADG5412F-EP FEATURES FUNCTIONAL BLOCK DIAGRAM Overvoltage protection up to −55 V and +55 V ADG5412F-EP Power-off protection up to −55 V and +55 V S1 D1 Overvoltage detection on source pins S2 D2 Low on resistance: 10 Ω S3 D3 On-resistance flatness: 0.5 Ω S4 D4 5.5 kV human body model (HBM) ESD rating Latch-up immune under any circumstance FAULT Known state without digital inputs present DETECTION FF + SWITCH DRIVER ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) IN1 IN2 IN3 IN4
001
Military temperature range: −55°C to +125°C NOTES 1. SWITCHES SHOWN FOR A LOGIC 1 INPUT.
12705-
Controlled manufacturing baseline
Figure 1.
One assembly/test site One fabrication site Enhanced product change notification Qualification data available on request APPLICATIONS Avionics Analog input/output modules Process control/distributed control systems Data acquisition Instrumentation Automatic test equipment Communication systems Relay replacement GENERAL DESCRIPTION
The ADG5412F-EP contains four independently control ed switching applications where excel ent linearity and low distortion single-pole/single-throw (SPST) switches. The ADG5412F-EP are critical. has four switches that turn on with Logic 1 inputs. Each switch
PRODUCT HIGHLIGHTS
conducts equally well in both directions when on, and each switch has an input signal range that extends to the supplies. 1. Source pins are protected against voltages greater than the The digital inputs are compatible with 3 V logic inputs over the supply rails, up to −55 V and +55 V. full operating supply range. 2. Source pins are protected against voltages between −55 V When no power supplies are present, the switch remains in the and +55 V in an unpowered state. off condition, and the switch inputs are high impedance. Under 3. Overvoltage detection with digital output indicates normal operating conditions, if the analog input signal levels on operating state of switches. any Sx pin exceed V 4. Trench isolation guards against latch-up. DD or VSS by a threshold voltage, VT, the switch turns off. Input signal levels up to +55 V or −55 V 5. Optimized for low on resistance and on-resistance flatness. relative to ground are blocked, in both the powered and 6. The ADG5412F-EP can be operated from a dual supply of unpowered condition. ±5 V up to ±22 V or a single power supply of +8 V up to +44 V. The low on resistance of these switches, combined with Additional application and technical information can be found on-resistance flatness over a significant portion of the signal in the ADG5412F data sheet. range make them an ideal solution for data acquisition and gain
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
